On a side note the resaon the previous owner thought valve seals is the motor had sat, alot, the rebuild was done in the mid 90's and between then and now its seen maybe 15000 miles...i do trust the old owner, he is a hardcore gearhead and seems pretty upfront and honest.....but still seems wrong...? |
Time for more diagnosis.
Compression Test Leak-down Test Read your spark plugs Pull the valve covers and inspect the valve seals. Have you climbed under the vehicle to look for any signs of leaks, if you have a pressure leak, it may only lose oil at higher speeds. |
Any chance worn out weak valve springs could be related? Espicially since the cam was swaped in a couple years ago and the springs were never replaced, not since the 90's anyways, and it sees 6g's fairly regularly....not sure if in any way a weak valve spring could cause this tho.....but thats the only time it will smoke, is 4500+, maybe even 5 +?
Actually an engine can burn a lot of oil and not smoke much if at all. The fact that it blows the dipstick out tells you the rings are not holding seal. Forged pistons can be a real PIA depending on alloy. The less silicon the piston has such as 2618 generally the stronger the piston but the greater the thermal expansion issues so they have to be run with pretty loose clearances so the rings have a harder time sealing, which is why racers run a vacuum powered vent systems to help seal the rings and to get the blow-by out. The 4032 high silicon alloy is more like hyper-eutectic material in cast pistons in that it's more thermally stable but is more brittle than 2618, therefore easier to fail. But for a hot street engine I think makes a better choice as it fits daily driving habits better. The 4032 alloy results in closer running clearances which do a lot to help the rings seal as they aren't being tipped as much as the 2618 piston relative to the bore. The 2618 piston needs to carefully warmed to operating temps before getting on the motor, otherwise the angled rings begin to beat out their lands resulting in a loss of seal that can't be repaired only replaced. The 4032 alloy should be warmed up but will react much more like a production piece in regard to riding pretty tight and straight to the bore wall thus holding ring seal. Of course what the specific problem is remains quite open. Events such as honing the wall for a 2618 piston, then running a 4032 nets the same problems, or worse, than the 2618 because the eutectic alloy will not expand enough to gap the clearance so it continues to rock when hot just like the cold 2618. Its complex, the machinist/builder really needs to know the properties of the alloy to be used and the type of ring among several other things when preparing the bore walls. This is a place where communication between owner'builder and the machine shop operater can easily become a series of missed or assumed information. A compression and/or leak-down test may not show a problem as these type ring seal issues are often not identifiable when the engine isn't running. Bogie Last edited by oldbogie; 06-09-2011 at 01:04 PM. |
loosing oil.
Hi,if you say you have a SLIGHT rear main seal leak,look at the drive shaft,bottom of car,and rear end for oil staining,you could be loosing oil only at high revs.
Do a backyard mechanic thing, drive it down the road in low gear to about 40, then let off the throttle, see if smoke rolls out. We did that in the old days, when I was a kid, thinking it was the way to test for wear.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
valve seals generally show up at idle after the engine sits for a while, everyone trys to blame something cheap when they are selling it.
Artificial Intelligence is no match for Natural Stupidity Chet |
| I'm frustrated with Edelbroke | BUFFALOBILLPATRICK | Suspension - Brakes - Steering | 2 | 06-16-2010 04:53 PM |
| frustrated | BUZZA | Hotrodders Site Suggestions and Help | 1 | 01-16-2008 06:03 AM |
| frustrated!! | Razors57chevy | Engine | 6 | 10-03-2006 11:43 PM |
| *****in Frustrated | Sixx Nine | Hotrodders Site Suggestions and Help | 4 | 04-16-2006 05:21 AM |
| Really Frustrated! | 32vicky | Hotrodders' Lounge | 15 | 03-17-2004 07:59 PM |
