So has anyone chosen NOT to rebuild their motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2005, 10:01 AM
Some cars are parked for various reasons that have nothing to do with the internal condition of the long block. Just curious if anyone ever just runs the motor without rebuilding it. I'm talking really old cars though. Say 40 years and older. It seems like people are so quick to just yank a motor and rebuild it. Sometimes this alone becomes so over whelming that the car never gets back together. I've seen many cars at swap meets 50 years and even older that ran as smooth as new and were never rebuilt. I would at least replace leaky gaskets and valve seals and put in a carb kit.
Personally, if I were on a budget and the motor ran solid, I wouldn't care how old it is. Modern oils offer a lot more protection than 50 years ago. I say, drive it till its truly needing a rebuild.
Just curious what is the oldest, non rebuilt motor you have seen that is actually driven somewhat regular.
Old 03-10-2005, 11:12 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
my brother has a 39 dodge car w/the stock flathead 6 in it. it had about 80,000 on it when he got it & drove it back forth to work (50miles each way)for about a year w/o a single problem other then running out of gas , the gauge is broke & he 4got to write his mileage down. other then changing the oil & adjusting the brakes he hasnt had a bit of problems w/it & its still running strong......joe
Old 03-10-2005, 11:40 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
The older engines are not built as tight (or as flimsy) as these newer ones, so they can be pretty worn and not smoke, blow head gaskets or warp heads and so on.
I just threw the dice on a 89 Ford Probe (junker), by putting a $40 head gasket on a worn engine with a warped head. It runs, but has low compression and water is mixing with oil and visa versa, but it is much better now that it's not a lawn ornament, and that it's worth more than the $50 a junkyard would give. So in the end it worked out.
But it's best not to cut corners if there is a chance it could come back and bite you in the butt. IMO
Old 03-10-2005, 11:54 AM
cboy's Avatar
Last journal entry: Finished
Not 50 years old, but my plan is to run a bone stock 351 out of the 1981 F-150 donor truck in my rat project without touching a thing on the motor except new valve cover gaskets. I haven't even cranked it over yet, but when the time comes, if it runs, thats as much as I'll do to the motor. Actually, when we built these things back in the 50's and 60's, a LOT of hot rods didn't have speed parts or overhauls. Transplanting a stock V8, even a tired one, was about all the power you could handle with a model A or model T light weight chassis. So I'm just claiming it's "period correct" to run a weezy engine.
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 03-10-2005, 12:53 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
refresh
The 454 in the Lemans pictured in my Avatar is a refresh not a rebuild. It is a 1975, 454, std bore.
The heads are 1968, 427, 100.9cc heads. Which I understand to be quite rare and are 37 yrs old.
Old 03-10-2005, 01:10 PM
Can't catch me!
I have an original 1962 impala with a 283 thats all original and has only had new gaskets and a few minor exterior engine components installed and it runs likes its brand new. but it also only has 86,013 miles
Old 03-10-2005, 01:18 PM
tbirdscott's Avatar
stuff'n things'n whatnot
I will be running my 1959 Zephyr with 108000 miles on it without a rebuild, may do seals though but it runs like a top even with 3 year old gas and a sticky carb. The 351W out of a 1979 econoline thats goin into my t-bird will probabally get pulled apart and a gasket set but nothings being replaced internally. I'm not worried
Old 03-10-2005, 10:16 PM
lluciano77's Avatar
Short changed on common sense
I got my '90 5.0 from a salvage yard for $200. They said it was a core that needed a rebuild. Teh cylinder walls were in great condition so I paid the cash brought it home. When I got it back I pulled the rod and main caps off. It was a fresh rebuild. All the bearings looked barely broken in. All I did was clean it up, retorque everything, and run it.
I know it isn't 40 years old, but it still fits your logic.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Help on a Pontiac 400 dirt track motor ridlenracing Engine 9 06-16-2007 10:26 PM
motor won't come out.. Trav Engine 42 03-02-2004 07:16 PM
mustang motor mounts??? shagginwagonvic Engine 3 01-19-2004 08:30 AM
Motor filled up with Water!!! tommytempest Engine 14 12-16-2003 11:19 PM
