I've got a program that I crunched some of your numbers in, and the way it is, you'll get approx. 235.1 hp @ 3500 rpm, and 379.4 lbs torque @ 2000 rpm. These are just rough questimates.
I would get a little bit bigger carb though. At full throttle a 500 cfm won't keep up, you'll be starving the engine. I would go with at least a 650 cfm or so carb. The only other horse power gains I could suggest would be run an electric fuel pump instead of a cam-driven mechinical, and go with an electric cooling fan, and an electric water pump if possible. That could put it up around 242 hp. |
your carb is killing you, you need an 800 or larger.
K |
You will be making more than 250HP with that combo.
I have the specs on my Bro's fresh rebuilt '77 400ci Fresh block bored .030 over Heads 3 angle port job Flat decked CR of approx 9.5:1 Stock Quadrajet 850CFM Edelbrock Pontiac Performer Intake Comp Cams, not sure which grind #, but approx .480 lift, not too lumpy. Probably forgot a few things, but anywhoo, when we ran all the data thru Desktop DYno it gave us 380HP, 420ft-lb. YOu're gonna want a bigger carb on there if you plan to bring it over 4000RPM. |
K |
yeah those calculations are way off, the HP is wrong too IMO.
K |
some good replys there cheers. i like the electric fuel pump idea and big carb ..carb is easy..can i jet my other one or is it a new one and electric pump di i have to get a block plate for the old one
i did suspect haymans was a tad off i think ive current ly got about 200 hp all that cant only give me 30 extra specially with a cam lifting high seventies...how would ram air iii heads go down i can get some for 600£ is this a good price |
jhaymans calculations are WAY off. A typical stroked 468 pontiac will put out at least 400 ponies at the flywheel depending on heads, cam, etc.
Go 800 or bigger. 69elcamino, this motor is not a "small" block nor is it a "big" block Pontiacs are the same block size 326-455. I have yet to see a 468 cubed small block by the way. Expect HIGH compression with the ram air 3's on a 468. Go with some Edlebrocks. Performance straight out of the box. Here, check out this 455 build up. This should give you an rough idea of the power you can be puttin out: http://www.carcraft.com/techarticles...ont/index.html |
