SO I'm driving along and... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2006, 09:38 PM
johnsongrass1's Avatar
Race it, Don't rice it!
My truck start's surging and missing and losing cylinders fast. I guess it's time for a tune up. Poor thing never gets any attention. I just beat on it till it breaks. I bought 8 AC Delco R45TS plugs and found this in tweo packages. Both plugs have the correct PN stamped on it. What's up with that?
Check the second pic for why my trucks performance is going down hill. Looks like a little oil control with a hint of additives.
Old 05-17-2006, 10:56 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You forgot to include pictures...
Old 05-17-2006, 11:27 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
this thread needs pics.
Old 05-18-2006, 01:21 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Earth to Johnson, Earth to Johnson, come in please.......
Old 05-18-2006, 06:33 AM
cboy's Avatar
Last journal entry: Finished
Here. This picture should solve everything. (he he)
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 05-18-2006, 07:18 AM
I think my dial up host timed out.
Pics would be good here.
Name:	Same PN different size.jpg
ID:	12328   Click image for larger version
Name:	Fouled plug 2.jpg
Old 05-18-2006, 07:24 AM
engineczar's Avatar
The one on the right snuck some Viagra into the package before it left
Old 05-18-2006, 07:27 AM
powerrodsmike's Avatar
Wiki Edits: 161
Now that I saw the pics, I still dont see the problem.
I pull plugs out of my ol yeller ford all the time. I just hit them with the needle scaler and put em back in. HA!
Seriously, what the hell kind of gas does that?
BE different....ACT normal.
Old 05-18-2006, 07:33 AM
Last journal entry: PICTURE TEST
That right there is funny,,, I don't care who you are...git-r-done
I would guess oil control with some typ of water getting into the cylinder also....
Keith
Old 05-18-2006, 08:52 AM
The last three of my daily drivers fouled plugs like the one shown. I've changed brands of gasoline and it helped the last time. Something the company is putting in the fuel. They make the stuff locally so every corner has a Break Time station. Some corners have two stations. It's usauly easier to get fuel at this station because the they so plentful. They make it harder not to buy from them. Seems to only affect me though. I don't get it either. I suppose as long as the A/F mixture stay lean, not enough build up exist's, but as soon as a peformance engine comes along that runs a tad rich at idle, the plug temps drop and stuff start's collecting. This is the worst plug, others were showing a build up on one side but normal color on the other. The mixture ring was about 7/8 around. This plug has been in there for a full year and some months. It's got about 25K miles on it. It's been a a few moths since I've even raised the hood. That's how neglected this thing is. lol
355 with 800cfmQ jet carb and headers, dual exhaust, XE268H cam. Ported 882 heads, 9.5 compression with cast flat top. I'm trying a R45TS instead of the old R43TS.
The plug lenght makes me have to run the longer plug on the cylinders that the exhaust tubes turn away from the plug so the wire boots don't burn. I could return them for something else but that would mean a trip to the part's store and that's like two miles up the road.
Old 05-20-2006, 01:18 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You are sucking up oil.
Some of the plugs are mislabeled on the assembly line.......
and you probably need 45's anyway.
Come on------ you are smarter than that....
Driving short distance in the morning - Does it hurt your engine/exhaust? Malibu73 Engine 12 10-26-2005 08:44 PM
Speaking of Style of Driving crazygutgut Hotrodders' Lounge 10 08-19-2005 06:13 AM
Driving Drunk RCastle Hotrodders' Lounge 16 01-15-2005 10:43 PM
what u dont want to happen while driving. 1Fast65Elky Hotrodders' Lounge 15 08-21-2004 02:35 PM
Did awsome on my driving. neil madsen Hotrodders' Lounge 9 03-05-2003 04:15 PM
