So I'm making an air cooler for compressed air... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2013, 09:15 PM
jsm1847's Avatar
I decided to embark on the path of air cooler with a condenser that I have read about on this site and others. I found a condenser for $20 that doesn't leak from a Pontiac Grand Prix. My main question is this... Is there a specific condenser that I should look for that has larger diameter pipe? I am assuming that if I tap into this condenser from my compressor with a much smaller diameter pipe, won't it reduce my cfm? Any thoughts?
Old 09-22-2013, 08:09 AM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
If you are concerned about removing moisture in the compressed air, you might want to consider using a Franzinator.
Old 09-28-2013, 04:34 AM
BWS BWS is offline
The franzinators work.....we call them expansion chambers(EC).
I went so far as to wrap the EC with 1/4" copper(ice maker line)that is "open loop",connected to shop's cold water line.It makes about 20 or so coils around the EC outsides,then exits into a bucket.
Under normal conditions we don't turn the water cooling on....but if we're going to be spraying a lot,or in any way have compressor running much,we set the water to a drip.
Also set it up to also use this water for an open loop Tig cooler....running waste into sink.
Ancient 60G 2 stage compressor.....with above system,the main tank rarely see's ANY funk/water.The EC gets cracked open about every other day,and blows out maybe a 1/2 cup.
Old 09-28-2013, 11:50 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I tried that and the condenser did not flow enough air to be of any value..The Franzinator reffered to does ork just fine..I place mine downstream from the compressor some distance.
Sam
water in compressed air, what do i need? 406 ss monte Garage - Tools 3 02-07-2010 09:51 PM
Trouble shooting Van Air compressed air dryer awert Garage - Tools 5 02-16-2009 02:46 PM
Compressed Air Question DONZIE Body - Exterior 15 10-05-2006 06:05 PM
Compressed Air Filter Irelands child Body - Exterior 1 09-13-2006 04:53 PM
