-   -   So its ok to set pinion angle with.... (http://www.hotrodders.com/forum/so-its-ok-set-pinion-angle-134091.html)
Hogwild 02-25-2008 10:28 PM
So it is ok to set pinion angle with the front wheels on the ground and axle stands under the axle..And this is a dumb question.(but hey you dont really know me) :embarrass soooo..With the angle finder where would i put it doesnt really seem to be anywhere flat(level) enought for it....ford 9 inch
Centerline 02-25-2008 10:48 PM
You can set the pinion angle as long as the weight is on the suspension. The angle finder is set on the pinion yoke perpendicular to the pinion gear.
