So its ok to set pinion angle with.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2008, 10:28 PM
So it is ok to set pinion angle with the front wheels on the ground and axle stands under the axle..And this is a dumb question.(but hey you dont really know me) soooo..With the angle finder where would i put it doesnt really seem to be anywhere flat(level) enought for it....ford 9 inch
Old 02-25-2008, 10:48 PM
Wiki Edits: 49
You can set the pinion angle as long as the weight is on the suspension. The angle finder is set on the pinion yoke perpendicular to the pinion gear.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 02:48 PM
Should Output Shaft Wiggle on THM200 4R? JohnTN Transmission - Rearend 20 11-15-2006 10:32 AM
Offset pinion and driveline angle? I nned advice. mike bryan Transmission - Rearend 4 10-25-2004 07:37 AM
1947 Ford truck ring and pinion set -NEED Pontiacman Transmission - Rearend 2 11-13-2003 06:02 PM
