Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - So its ok to set pinion angle with....
Old 02-25-2008, 10:48 PM
Centerline Centerline is offline
Wiki Edits: 49
You can set the pinion angle as long as the weight is on the suspension. The angle finder is set on the pinion yoke perpendicular to the pinion gear.
