Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - So I've got a couple of problems!
Old 09-01-2009, 03:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You could use a stock, 5 qt. pan and pick up for same. It will clear a 3.75" stroke, just check it to be sure that it hasn't been bent previously- the OEM pans will clear a 400 stroke crank, though.
If you need the extra capacity and depth, there are other pans that have the same "footprint" as the OEM pan, only deeper. It would obviously require a deeper p-u.
