So.. what are the best Hot Rod plugs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2013, 12:18 PM
I know this is a loaded question but I was wondering if there is any general advice as far as Hot Rod plugs go. Not necessarily a long life plug but one that resists fuel fouling, works well with a carburetor, ect.
The reason I ask is because everyone has said use NGK copper plugs. I have had a couple plugs go dead just sitting over the winter. I switched to Autolite a few months ago and so far their fine.
Any advice on plugs too use? Or plugs NOT to use?
Old 04-01-2013, 12:24 PM
Banned
ones that fire....lol
what are these going into?
usage of vehicle/etc
Old 04-01-2013, 12:33 PM
c
Exactly! LOL, seems like a lot of people go through several sets of plugs to find one that works right.
Its a Chevy 383 with Vortec Heads
XE-274h cam 1.6 roller rockers
Crosswind Intake
Holley 850 DP
Davis DUI
Long tube fenderwell headers
Old 04-01-2013, 05:13 PM
Anymore, I usually select the plug to fit the headers so I don't have to dimple them for plug-boot clearance. Often as not, that ends up being NKG as an eighth inch shorter insulator and a choice of heat ranges makes for a lot of flexability in fitting around headers and maintaining proper in cylinder temps.
Bogie
Old 04-01-2013, 09:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Whenever possible, I use extended tip plugs. They have a broader sweet spot than regular plugs and they work well in many applications. The piston clearance needs to be taken into account w/small chambers and/or domed pistons.
If difficult installation is an issue, using double platinum or iridium plugs (double, meaning both the center and ground electrode has the special metal, not a double electrode) can extend the useful life of a plug, requiring fewer changes through the life of the engine.
In my opinion, the U-groove, diamond tip, double and triple electrode plugs are no better than a normal plug. Champion plugs are supposedly poor quality compared to what they used to be. I use AC, both regular and platinum.
Old 04-01-2013, 09:11 PM
For the vortec cylinder head the autolite 605 works well. It is a shorter plug and works well with header clearance.
Old 04-03-2013, 08:18 AM
I prefer NGK; but for no other reason than they have a lot of choices and a consistent product. I had a turbo Daytona years ago and I put Bosch platinums (+4?) in it after the usual popped head gasket. Ran like a 3 legged arthritic pig on ice...it was just awful. Pinged, fouled plugs, etc etc. Switched em out for standard NGKs and no problems. Now this does not mean all Platinums are awful, this became quite a well known problem with the turbo Dodges, and probably had more to do with high boost and chamber design than the plug itself.
Old 04-03-2013, 11:10 PM
if you beat my boat, well race
the best plug for my hotrods are buildge plugs
December 2012 Hot Rod Art Contest: Christmas Hot Rods Jon Hot Rod Art 20 12-22-2012 01:06 PM
Vote in the October 2012 hot rod art contest: Hot Rod Halloween Jon Hot Rod Art 0 10-25-2012 12:56 AM
October 2012 Hot Rod Art Contest: Hot Rod Halloween Jon Hot Rod Art 25 10-22-2012 09:38 AM
April 2012 Hot Rod Art Contest: 1950's Hot Rods Jon Hot Rod Art 43 04-21-2012 04:41 AM
February 2012 Hot Rod Art Contest: Non-Woody Hot Rod Station Wagons Jon Hot Rod Art 41 02-27-2012 04:06 AM
