So you think royal purple is THE oil! - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 07-11-2011, 04:09 PM
Banned
Originally Posted by cool rockin daddy
What a joke. Send in oil for analysis, use this synthetic over that synthetic. Change your oil at the intervals that are correct for the way you drive your vehicle. The typical condensation problems that dilute and denigrate oil additive packages in today's oil rarely happens in our cars because they are not subject to short duration drives before they are fully warmed up. Do any of you really think we need most of those additives in our oils? Aside from ZDPP, what do we need. Detergents? If you aren't going to change your oil every 5K miles (or less, depends how much you go cruising in a given year) you probably don't need them. This is just more of the typical hotrodder attitude that if a little is good, than more must be better. This leads to our overkilling everything about our rides. If a grade 5 bolt was used by the factory to bolt a subframe to a unibody, a grade 8 must be better. The list goes on.
Compare an engine running 5w30 penzoil to 5w30 valvoline- both conventional oils and you will see a HUGE difference, yet both have the same grading on many tests, share similar labeling, similar price, and can be found next to each other on the shelf at any store that sells oil. Penzoil is some NASTY sh1t, and valvoline is great for a lot of daily drivers. the same thing can be said when comparing synthetics. Despite labeling and certification there is still a huge difference between oils. We may not need $10 a quart oil in our cars, but when the cost is nearly the same (often less than a $5 difference for a 5 qt jug), then why not worry about getting the best value? Or getting the most mileage from your engine.
Valvoline offers a 300,000 mile engine guarantee if you use their synthetic, Ive seen cars go way beyond that with just their conventional. I've also seen engines look like hell after 60,000 miles with other brands, driven by people who thought "oil is oil".
I've seen it first hand so I really can appreciate the difference, I understand that many people cant because to the naked eye- it all looks the same.
  #47 (permalink)
Old 07-11-2011, 05:07 PM
cool rockin daddy's Avatar
Your ANECDOTAL story is amusing but without something more scientific than your opinion of Pennzoil being "nasty sh1t", that's all it is, an anecdote. I can go back and find threads where posters swear by Pennzoil as the best. Opinions on oil are the same as opinions on what engines are best......numerous, varied, and no one single opinion is the correct one.
  #48 (permalink)
Old 07-11-2011, 05:19 PM
T-bucket23's Avatar
Wiki Edits: 26
Every auto manufacturer has standards that they require. Unfortunately the labeling on oil is very convoluted and deceptive. The other unfortunate part is the issues that show up from using the wrong oil don't show up immediately. It usually takes time for the issues to pop up. This is very prevalent in overhead cam engines.
Chet
  #49 (permalink)
Old 07-12-2011, 12:26 AM
Im really getting into this oil thread! Lots of good points. I wonder what real changes have been made in the last 10 years? I mean the price for syn oil has fallen to near dino prices. Supply vs demand thing. No doubt there all blends from only a few original suppliers. Really has anyone other than me ever purchased summit or jegs brands? I have and have been pleased in the value that I got in the parts.
Also anyone computer savvy? I think this therad needs a new smilley, a red face and a purple face having a pissing contest.
  #50 (permalink)
Old 07-12-2011, 03:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 68NovaSS
Thermal breakdown is a major cause of failed lubricating ability. That's wearing out.
I read an article in Scientific American on motor oil, and the concept was laid out that the chains of hydrocarbons were sheared into shorter chains as the motor oil was "used up", up to the point that there was a significant amount of "wear" that had, in fact, taken place. Take it for what it's worth- I have no dog in this either way.
AFA needing to have some sort of special, engine-specific oil that is somehow required for an engine- same as a piston is specific to an engine- has not been my observation. As long as a reasonable service interval is followed for filter and oil changes (I still use 3K miles as a guide) and the motor oil has the correct API service rating for the application- or supplements are used if it's lacking, I say all is fine.
But in all the years I've built, driven and raced engines, I've NEVER had an engine failure due to motor oil (or filter) failure. And I have never used synthetic motor oil (except when requested). And I use Fram filters if they're on sale.
I recently saw an article (I don't recall where) or ad that showed the relative amounts of zinc and phosphorus contained in various break in and motor oils. This was likely in Car Craft, only mag I still get and the 'scrip will thankfully be done soon (well-meaning relatives gift). It showed Lucas oil (might have been their racing oil, I don't have the mag handy just now) to have more additives than some/most of the tested break in oils, and more than enough to use 50/50 w/"regular" oil to have enough zinc and phosphorus for flat tappet cams to be 'safe'.
  #51 (permalink)
Old 07-12-2011, 09:02 AM
I would just mention that if you have a late model European car that you particular attention to the specs from ILSAC and ACEA for selecting the proper oil. Porsche,BMW and Audi are the only cars that I have seen have catastrophic engine failure from the use of improper oil.
  #52 (permalink)
Old 07-12-2011, 09:17 AM
Banned
the sludge and grime and leaks seen on penzoil engines were not just stories, they were as real as any other oil related issue. You can literally tell a penzoil engine by the smell when you pop a valve cover.
Again, I realize my experiences are not the same as others, and that to most people "oil is oil" I just know enough to stay the hell away from that crap.
In my line of work it is common to see different products that all have the same or nearly the same published specs- however even though many aspects are the same they can vary SIGNIFICANTLY. Its the same with oil certifications, passing some criteria still leaves a lot of aspects that can vary.
  #53 (permalink)
Old 07-12-2011, 09:34 AM
Add VW to that list - particularly the diesels. The wrong spec eats cams. And no, when 502.00 is required, using a higher number doesn't guarantee backwards compatibility. Euro standards aren't close to ours.
  #54 (permalink)
Old 07-12-2011, 12:10 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I have to smile when I read stuff like this. If the oil has the API and ILSAC ratings that are required for your engine, and is in the correct viscosity range, it will protect your engine. Doesn't matter if it is synthetic Penzoil, dino Penzoil, Royal Purple, Mobil 1, Wal-Mart Tech brand, AutoZone or any of the myriad of oils on the market. As long as it has the correct ratings, it doesn't matter.
Telling what oil is used by the "smell", or deposits left behind is laughable at best, as well. Deposits are normal, heavy sludge is not. Sludge is not going to be left by ANY properly graded oil, UNLESS the owner has far exceeded the required maintainence interval, abused the engine, severly overheated, or does many short drives with no warm up. In my years as a professional technician, 99% of the sludge and heavy deposits in engines were a driect result of operator neglect and abuse. The other 1% was due to incorrect oil grades and/or "mechanic in a can" additives.
P.S: Next month is 18 years, I have been inside a few engines.....
  #55 (permalink)
Old 07-12-2011, 12:26 PM
AntnyL's Avatar
Oh, so by leaving a very generalized disclaimer your original generalization applies to "everything sometimes, but not always, unless it does, but you're never sure?"
In that case anything liquid will work as long as you use the proper type.
There are many different grades, types, classifications, etc for oil- so which ones matter and which ones don't?
Yikes. Never mind.
  #56 (permalink)
Old 11-19-2013, 07:34 PM
Mileage and power gain of Royal Purple
The claims of of some of the super premium oils and additives is confusing and I just don't know if the extra cost is worth it. I remember a consumer magazine always touted as long as you change oil at the recommended interval, additives aren't needed.
I see on the forum where Mr. Gil has an article "So You Think Royal Purple is '"THE" Oil and then shows where Royal Purple agreed to change advertising claims with NAD (National Advertising D?). This was in response to BP Lubricants
taking Royal Purple to task, showing horsepower and mileage claims don't add up.
Well I'm just a regular guy wanting to take care of my car with quality oil. I was just wondering on how did you performed the test whereby you do see an increase in miles per gallon. Was it done with a certain amount of fuel say one gallon of fuel where under the same conditions as before the switch was made to Royal Purple? Of course the the additive makers compare themselves against each other. I believe I saw where Amsol and Bestline were two that did this, but I'm not sure.
I know it may sound foolish to s some, but the reason I'm asking this question is that I do mileage checks on my car after filling up several times to the max. I'm talking about filling up to the neck of the tank until it runs over, which I do not recommend, but sometimes that did occur.
I found that sometimes it appeared that I got say 4 or 5 miles a gallon increase, but then the mileage would average about the same later on. Of course checking miles per gallon this way, neither confirms or denies an increase for obvious reasons. You just aren't going to drive the same speed, go the same routes, and a number of other variables.
  #57 (permalink)
Old 11-19-2013, 08:39 PM
Banned
You will see a slight increase in mileage with fresh oil. New oil is not the same as used oil, and the quality of used oil can vary all over the place.
Use a good oil and filter, change every 3000 and you'll be fine on that. With proper maintenance many engines are going to near the half a million mile mark now.
  #58 (permalink)
Old 11-19-2013, 08:59 PM
Originally Posted by shine View Post
no thanks. i'll stick with Mobil 1 .
Think again
  #59 (permalink)
Old 11-19-2013, 10:22 PM
Semper Gumby
Wiki Edits: 2
After so many years of owning, driving and manintaining so many cars, including a owning small fleet at one time, I have come to the conclusion ("leapt to the confusion"?) that virtually ANY synthetic oil will be a humongous improvement over ANY "conventional" oil.
Doesn't seem to matter if it is Syntec, Mobil 1, Pennzoil, Q-State, Royal "Burple" , Red Line, or some store's house brand synthetic - all will outperform the conventionals, but choosing between them is a bit more challenging! There is no "right" answer - and also no "wrong" answer Despite what the advertising hype will say about any one brand.
For every person who has gone a zillion miles on "Brand X" with no issues, there are 10 more folks who have gone equally far on Brand A, B, C, D or whatever - also with no issues.
What filter you use is at least as important - maybe even moreso!
The MOST important factor is how often do you change the oil. Do follow the car manufacturer's recommendations ("Change it every 500 million miles and we'll see you again in 3 years for another new car") or do you use your head and realize that oil & filters are the cheapest insurance you can buy - anywhere!
  #60 (permalink)
Old 11-20-2013, 11:28 AM
Your post makes the most sense.
A consumer magazine said as long as you change your oil at the recommended intervals, that is all you need to do for proper protection. Additives, some quite costly are not necessary. I do believe from what I read on the pros and cons of some oils, you may have longer protection than others, because some of the various concoctions of additives may last longer than others. Although I'm not heavy into automotive stuff, this is an interesting forum. Opinions are from one extreme to the other.
oil psi problem w/350 A355CAMARO Engine 1 04-19-2007 08:25 AM
Oil Filter relocation kit... jmbjs Engine 4 04-11-2006 09:15 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
Royal Purple nomis30 Engine 5 09-28-2003 08:31 PM
royal purple??? Vancouver Grand Prix Engine 1 04-21-2002 06:04 PM
