Socket for crankshaft bolt? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2012, 06:01 AM
51 Chevy 3600
Last journal entry: Front straight axle from 1951 Chevy 3600
I need some help. I didn't think I was that incompetent, but I prove myself wrong every day. Today's challenge. I want to manually turn over my chevy 350 but I can't get a socket over the crankshaft bolt. I tried every socket I had. The other bolts are 9/16 and look to be the same size as crankshaft bolt. I went to Napa and bought thinner walled socket, but It won't fit either. Do I need a special tool???
Old 11-12-2012, 06:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Best bet is to remove the pulley. Otherwise it'll take grinding down the OD of a chinese socket (one that you don't care about).
Be VERY careful turning the engine over using the crankshaft bolt! It's not made for that and if it snaps off your in for a lot of work. If you are bound to use it at least remove all the plugs and if the engine hasn't been started for some time turn it over using the starter to free things up.
There are tools that bolt in place of, or in some cases will mounts over the pulley (see image below). Much safer and easier to use, too. You can make this tool fairly easily. Click on images for info:
Old 11-12-2012, 08:25 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
If the H/B is off this works of the crankshaft key and is a good tool to have in your tool box.Don't try to turn over the engine off the crank bolt.
Proform Crankshaft-Turning Sockets 66901 - SummitRacing.com
Old 11-12-2012, 08:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I forgot to add...
If for whatever reason you have to use the bolt, your safest bet is to turn it using a clicker torque wrench set to 65 ft/lbs. If the crank will turn at that setting, fine. But if you exceed that torque you are taking a chance on stripping the threads or breaking the bolt outright. Usually the threads will let go first, but there's no guarantee.
Still the best thing to do is a tool made for the purpose.
Good luck.
Old 11-12-2012, 04:26 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I bought the second turning tool (the flat one) that Cobalt posted thinking it was better because it had a large variety of mounting holes for different engines and the offset ratchet point offered greater leverage for turning hard engines, plus worked on 3/8" and 1/2" drive ratchets. These are all true and good advantages, but I soon realized after I had this mounted on my balancer that it would not clear the water pump, and even if it did the breaker bar would not clear it. Not only that, but since the ratchet holes are offset you cannot use the ratcheting action (you have to turn the bar a full 360 manually). Basically it is fine for building a shortblock on an engine stand, but that is about it.
The first one Cobalt posted fixes all these problems, and works on short and long blocks and an engine that is installed in the vehicle. You just lose a little leverage. I wished I had got this tool instead because it is much more flexible.
The Following User Says Thank You to Silver Surfer For This Useful Post:
cobalt327 (11-12-2012)
Old 11-12-2012, 05:24 PM
51 Chevy 3600
Thanks for the replys
Thanks for the link to the wrenches and the sound advice. I should have mentioned that the engine runs (Just really rough.) Since I wasn't sure what the guy before me had done, I planned on tuning it. I tried tuning by ear, but I must be deaf.. So I thought I would start fresh. Planned on pulling the spark plugs and locating TDC. Since it is just me ,myself and I, bumping it with the starter wasn't going to be easy. (that is why I was going to turn it by hand.) Can't tell you how much I appreciate this site. I have been stalking it for awhile trying to soak up some knowledge. I finaly have something to wrench on now and I know just enough to do some real damage!
Old 11-12-2012, 05:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some info on finding TDC: Click here.
Old 11-14-2012, 06:18 AM
Irelands child's Avatar
I use the balancer bolt regularly on my Ford engines, but they are 5/8-18 not a Chebbies 7/16-20 plus I use an ARP 200,000 psi replacement. But with that said, I'll always pull the spark plugs too instead of trying to force the turnover past compression.
Of course, the best is still a special socket
Irelands child
Old 11-14-2012, 07:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your Ford is the same size thread as the Pontiac uses. 160 ft/lb torque on the Pontiac, though.
Old 11-14-2012, 07:35 AM
OUCH!!
Ford torque is 90 lb ft (actually 70-90) which is not much for a 5/8" bolt. I generally split it to 80, but after using it for turning over the engine - who knows, but it is still probably no more then the 'official' torque range with plugs pulled.
Dave W
Irelands child
Old 11-14-2012, 08:52 AM
Should take no more than 30 to 50 ft lbs to turn your engine over fully assembled. Takes 40 on mine. Sure you could apply more but be carefule.
Crankshaft bolt is slipping and tightening Bauer1287 Engine 1 11-12-2010 08:27 PM
SBC Crankshaft bolt carteen007 Engine 2 06-29-2010 09:10 PM
Chevy crankshaft bolt 69DartGT Engine 11 04-27-2008 09:45 PM
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 07:27 AM
Socket Size JT Rooster Interior 10 12-31-2004 10:27 AM
