Soda blasting - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2005, 01:42 PM
BadAss_Beaver's Avatar
No Replacement 4 Displacement
Soda blasting
What is soda blasting and how does it differ from media blasting? also which is the better process to use for cleaning up a body down to bare metal?
Old 07-20-2005, 06:11 PM
BarryK's Avatar
Soda, leaves a film that must be neutralized. (not easily done!)
You want no part of it.
Go with the media.
There are many past posts on this subject explaining this, if this answer is not convincing.
Old 07-21-2005, 07:07 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Soda (baking soda, in simple terms) is a one time use product. It fractures. If it is not 110% cleaned off the surface, and every crevice, it will react with the paint. You ought to see what it does to PPG DP90LF after a week of it being on. Me, always having to see things for myself, blasted a section of an old wagon. (CLosest junk I had) Thought I cleaned it well with DX330, and shot some DP on it. Looked OK when I did it. There wasn't much left of it on the wagon when I took it to the dump. Think Baking Soda and Vinegar.
Soda is good for PAINT removal only. No rust.
Some time ago, I considered building a shop that specialized in Soda blasting. No one around does it. After a ton of research, I found that you really couldn't make any money at it. Bodyshops will D/A a car off, in less time than it takes to blast, clean and neutralize the car.
The biggest thing I found so far(as a newbie) ......take a tried and true method (sanding), and get right to it. Mediablasting can save time in COMPLEX areas with a lot of shape, but YOU STILL HAVE TO BE CAREFUL! The media is being shot at the car under pressure. Pressure distorts metal to some degree. Think not? Aim just your air nozzle at a soda can, and give it a blast. And thats just AIR. Now add mass to the equation.
Aesops Fable:
The more you look for an easy way, the longer it takes, and the more aggravating it becomes.
Old 07-21-2005, 06:24 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
media blasting is done at low presure /high volume. i use platic to remove paint and some surface rust. i switch to starblast to get the rust spots or when doing a frame. once you've stripped.......you'll never go back. it is unbelievable how nice it is to work with clean sheet metal. it cuts prep time to nothing. and painters hate prep
Soda Blasting VS. Chemical Dipping iwanta32fordtruck Body - Exterior 4 12-21-2004 02:09 AM
soda blasting badriand Body - Exterior 19 11-01-2004 09:03 AM
B]great Solution To Soda Or Sand Blasting luckky1 General Rodding Tech 3 08-31-2004 06:47 PM
What the *@#$&%!!! is soda blasting zachscc Body - Exterior 4 10-31-2003 06:16 PM
