Soft Bayonet type shocks for Model T - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2007, 09:13 PM
I have a model t hot rod that is a bear to drive on some freeways. The shocks are bayonet style (like 1st gen mustang). Because the car weighs nothing...the bumps are quite hard. Anyone cure this prob? If so, what mfr, p/n ?
Old 04-14-2007, 01:48 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
What spring setup are you using? If it is a semi elliptical cross spring how many leaves do you have in the pack? Do you shocks bottom out when you hit bumps? At rest do the shocks sit about half way between their travel?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-14-2007, 03:45 AM
Take the shocks off and do some more driving around. You might find that it is still just as stiff which would mean your problem is the springs.
Old 04-16-2007, 12:17 PM
Interim solution
Here is a history of my exploits:
Found street driving harsh and freeway driving with bad expansion plates was so bad it caused the car to self destruct.
Went to the junkyard looking for smallest possible wire coil ... had to pull them off a late model econo car (actually separating them from a coil over assembly). Nothing smaller.
Tried new non-adjustable shocks in case old ones were somehow stiff because of a clogged valve.
The stiffness eased up but only about 10-15%. Clearly the shocks were the problem. I needed shocks to have soft rebound control and 0 effect in compression...to benefit from the small springs.
I tried driving without shocks. The oscillation was spooky on 45 mph surface streets, and really wild on the freeway. I loaded the trunk with about 80 pounds of weight, but oscillation still required a slow, dangerous freeway drive. If you want a "Mr Toads Wild Ride" without long lines of disneyland, this is the way to go; pay up the life insurance.
I looked in a summit catalog for adjustable bayonet shocks. I happened to have some expensive Koni adjustable bayonets. I didnt want to resort to it (the were installed on an expensive race car setup), but I put it on Sunday. They are not 2 way adjustable, nor are they externally adjustable. Before installation I set them to the absolute softest level...so soft they are held up by the coil springs. Subsequently, the surface street driving is pretty darn nice...but freeway driving is still a bear. I'm also thinking that this ride is partly to blame but a high ratio of unsprung to sprung weight. The unsprung weight is probably equivalent to a 1970 Ford Maverick, yet the sprung weight of this model t is probably 1/2 of a Maverick's sprung weight.
Old 04-16-2007, 12:23 PM
Any T roadster can be made to ride quite well if suspension components are correctly chosen and installed.
Most Ts are built with springing that is too stiff which makes a hellish ride and even with shocks(how can a shock work if the spring is not functioning?) doesn't work that well.
Plus, most T roadsters have seats which aren't really seats but poorly performing foam blocks with pretty upholstery. A stock T seat spring works wonders in the comfort department.
First, walk up the car, put your foot on the front perch and push down. If the car doesn't react unless you stand up on the perch then you have a suspension problem. You should be able to push down and have the car bounce once or twice and come to rest. This applies front AND rear just like any other car.
Are your shocks mounted so that they have working room? Often, folks mount shocks with not enough travel room and they bottom out giving you that jarring bump.
If your car has coil-overs, rear or all around, and they are not moving much, try a lighter set of springs.
Old 04-16-2007, 02:50 PM
prev questions
to answer previous questions, there is no issue of bottoming out. i think coil and shock travel looks normal. front is traverse leaf, rear is coil. honestly, the coil came from a macpherson strut...the smallest you could find.
Old 05-02-2007, 08:37 PM
instead of just eyeballing it, i measured it, and did the math, and inadequate shock travel is a major cause... prob is, it already 14" coils and finding 16" x 4.25 OD coils is not easy...
well, thanks for the tip
Old 05-02-2007, 11:16 PM
home brew's Avatar
How many leaves in the front spring?
Old 05-03-2007, 09:05 AM
So your rear shocks are bottoming out. You should be able to modify the shock bracketry to allow for more travel without killing the car for too long.
If the shock is installed inside the coil spring, either extend the upper mount or drop the lower mount to allow for correct travel (I did this to my Old Roadster and the ride became excellent from horrid). If the shock is outside the coil spring mounted at an angle (30-45 degrees), the easiest way to change this is to move the lower bracket inward and down to allow the shock more travel at a less steep angle. It may even be possible to make a temporary bolt-on bracket(bolts to the old bracket) to make this shift possible and allow for repair and restoraion during the non-driving season.
Old 05-03-2007, 09:20 AM
Dugg's Avatar
My compass doesn't point North
......... a couple of real amateur questions here ... hey, there's stuff I do know about, so keep the snickering to a low roar.
What is a "bayonet type" shock I've seen; tubular, lever hydraulic and lever friction, but I'm not familiar with the term bayonet.
As long as you're in a good mood now, a second question. What is the meaning of the Barnstar next to so many members names? And, are these rusty cast iron looking stars available for purchase? I think they're neat and I could see making candle holders out of them for art fairs. Sure, now even I can hear you laughing from here.
I've done some stainless steel furniture and a couple of artsy gates and I think the stars could become a trademark for some of my junk.... ooops, I mean art.
Old 05-03-2007, 02:05 PM
home brew's Avatar
A "bayonet type" shock is a tubular shock.
Barnstars are given to those contributing to the Crankshaft Coalition Wiki (link at the top of the page).
They were originally used on barns as decoration and would be much to big to be used as candle holders. Why not make up a mold and cast them yourself or you could make them out of clay and glaze and fire them.
Old 05-04-2007, 08:57 PM
imagine pulling shock absorber and trying to stab a part store clerk. if he survives because it has a "eye" at the top for horizontal bolts or a "T" for two bolts, then its not bayonet...if he dies because it has a threaded stud on each end, then its a bayonet style.
Old 05-04-2007, 08:58 PM
it is concentric with the coil...i'll have to arrange alternative, taller mounting space...thanks for the ideas.
Rear Drag Shocks on a Street Car? JohnTN Suspension - Brakes - Steering 2 08-09-2005 05:25 PM
What Front Shocks for a Softer Ride? Doc68 Suspension - Brakes - Steering 3 12-03-2003 08:39 PM
