Soft Brake Pedal
Strange problem. Thought maybe I could get some help.
I have a 2005 Town an Country with 3.8 I replaced rear brake pads(disc) but needed to push in the piston so I loosened the brake line just a little on each rear caliper and pushed in the piston with the brake pad in place than quickly tightened the screw. I thought no problem, WRONG pedal soft to the floor. Bled the rear brake calipers still soft, took it to local repair shop they also bled rear and front but STILL soft pedal. System has NO leaks and never any problems. Any help would be great. All my friends are stumped. |
Soft Brake Pedal
I'am Bleeding from the bleeder screw
Try a different bleeding method
I had this same problem occur with a corvette. The only way I could get the air out of the lines was to gravity bleed the calipers. Smack the calipers with a plastic hammer while bleeding. Start with passenger rear, then driver rear, then passenger front, and last driver front. As long as your master cylinder is higher than your calipers you should be able to gravity bleed.
| Soft/Low Brake Pedal | MidnightFord | Suspension - Brakes - Steering | 3 | 09-01-2011 08:05 PM |
| Occasional Soft Brake Pedal, cant figure out why | Z-Money Pit | Suspension - Brakes - Steering | 8 | 08-12-2011 04:05 PM |
| New Disc Brakes but soft pedal | ducrider123 | Suspension - Brakes - Steering | 12 | 07-04-2011 10:06 PM |
| brake pedal hard then soft but hardly any brakes | Wildwestshow | Suspension - Brakes - Steering | 1 | 12-24-2010 07:18 PM |
| soft brake pedal | jum | Suspension - Brakes - Steering | 5 | 03-05-2006 07:14 PM |
