soft brake pedal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2006, 01:23 PM
jum jum is offline
soft brake pedal
I just finished putting disc brakes on 1965 nova. Everything is hooked up correctly. Yes I bench bled the M/C. Individual lines are run to each disc brake up front. One line runs to the rear axle and the drum brakes are fed off it. (individually) The left front, right front and right rear brake fluid are clear and no bubbles coming from them when you bleed the brakes. The left rear still has a few bubbles coming out when brakes are bled. when applying the brakes The brake pedal wont stop until its about half way to the floor.(pedal is soft until you get half way to floor then wont go any farther.) Can anyone help with this problem? Thanks in advance Jum
Old 03-05-2006, 04:17 PM
302 Z28's Avatar
Are we talking a power system, if so you may have a bad booster. If not, you still have air in the lines IMO.
Vince
Old 03-05-2006, 04:55 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
sounds like theres air still in the system. Get a helper, crack the lines at the master cyl, have helper push pedal to floor and hold. Then close the lines and have helper release pedal. Do that at least 3 times. then see how the pedal feels. Good luck.
Old 03-05-2006, 05:46 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If you keep getting little tiny bubbles at the wheels despite putting two pints of fluid through it, the M/C wasn't bench bled properly. Take the lines off at the M/C, put the plugs back in and give it some more bench pressure.
Old 03-05-2006, 06:33 PM
jim..'s Avatar
That 6 Cylinder Guy
Also make sure rear drum brakes are properly adjusted,if they're out of adjustment you will get excessive pedal travel.
Old 03-05-2006, 07:14 PM
Bowtie or Die!
Yep hes exactly right on that!
Please help with my soft brake peddal Jeep'n Suspension - Brakes - Steering 14 12-27-2010 06:39 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Heavy Brake Pedal Question bluesman123 Suspension - Brakes - Steering 0 05-23-2004 10:41 AM
Brake pedal Clunk montea Suspension - Brakes - Steering 3 05-19-2004 08:34 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
