Soft Break-in Valve Springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2005, 04:48 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Lunati calls for soft break-in springs to be used on their cams. I'm using a solid roller, even though I have spring pressures that exceed their rule (I have something like 260# closed 515# open I believe) for using soft springs, is it really necessary on a roller cam? If so, I'll do it but it seems the roller wouldn't matter.
Thanks, Larry
Old 01-25-2005, 05:21 PM
BOBCRMAN@aol.com's Avatar
Not needed on a roller cam, for flat tappet cams with more than 125 lbs on the seat.
Old 01-25-2005, 10:01 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
cam break in
Not necessary on a roller.
But when necessary. Most people just remove the center springs and start the motor with the outer springs. Once cam is broke in, replace center springs.
Old 01-26-2005, 12:47 AM
camaroman7d's Avatar
I agree I have never heard of using lighter springs to "break in a roller" cam. What I do with flat tappet cams is use my "break in" rocker arms they are low ratio (1.2) and that saves me the trouble of having to pull the heads apart on the car. I just swap out the rockers adjust the valves and I'm done.
Royce
Old 12-21-2005, 07:51 AM
Last journal entry: ok im on to my next big dream beast
Royce
just wanted to say thats some good thinking im down for any thing that keeps me from wasting time and extra engine work is not something i look forward to i have a Garage Mans Companion myself that keeps me company already more than i need
Old 12-21-2005, 11:05 AM
roy383ci's Avatar
camaroman7d were can i get
1.2 rockers for my smbl
and btw camaroman7d would you still want to look what springs i got to use with the lunatie cam
Old 12-21-2005, 12:14 PM
You can get the roockers at www.speedwaymotors.com If you can't find them online give them a call they do have them.
Are you asking me to figure out what springs to use?
