Soft Glue Lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2011, 10:38 PM
Soft Glue Lines?
I just read it in a description for a adhesive. What exactly do they mean?
Old 03-25-2011, 08:20 AM
DanTwoLakes's Avatar
Wiki Edits: 22
When bonding some things together, especially dacron polyester wrap, the edges of the two pieces can get crispy where the parts are glued together. If this glue doesn't do that, it produces soft glue lines. No glue does this that well, some do it better than others.
Old 03-25-2011, 09:28 AM
So then, I guess this can happen if you use too much glue as well?
Old 03-25-2011, 11:59 AM
Wiki Edits: 22
It isn't really a function of how much glue you use, it has more to do with how the glue reacts with what you're gluing.
Old 03-25-2011, 12:39 PM
Ok, now I get it.
Turbo 350 fluid lines leaking is there better way to plumb lines? heathj1 Transmission - Rearend 3 11-08-2009 06:25 PM
Soft Top pletcher Body - Exterior 1 01-23-2007 03:14 PM
Big bar soft spring garyohdare Transmission - Rearend 1 12-18-2005 11:14 AM
looking for cheap soft top 31ford Body - Exterior 5 11-01-2004 11:46 AM
