Soft and unsafe brakes.
Alright, so one day my brakes were all of a sudden not working. I inspected everything at it looked fine. Tested the master cylinder and booster..Then my dad was apparently worried for "safety reasons", which i understand so he took it to a shop and they told us the master cylinder and the proportioning valve was bypassing. So I ordered the parts and my neighbor who helped me install them said its almost impossible for a proportioning valve to break, so we replaced the master only and bleed the system WITHOUT USING TUBING. Then when I first rode the car, the brakes felt better than when they were broken, but about 1/2 strong as they used to be.. To save cash i got a $25 master cylinder of Rock Auto, and im thinking that the cheap master cylinder doesn't work very good?? Or could it just be the PP valve that needs to be replaced? I checked the booster as well and its fine n dandy . Thanks!
Also, when I slam the brakes (when I was checking them) the wheels will not lock up anymore! It just decelerates when i slam it.. |
Sounds like cheezie brake pads on the front (low friction co efficient) and possibly frozen wheel cylinders in the rear. Have you looked the entire system over?
Also if the pads in the front are rusted into the mounting area and wont move(without a hammer) then they wont apply well either. Believe it or not that is a common issue, especially in the rust belt. Service the fronts pads/mount area, making sure the pads slide freely, check the rear to be sure the wheel cylinders move when you step on the brake.
Fact is stranger than Fiction |
Yeah but im pretty sure the wheel cylinders are ok, because the shop checked all of that..Isnt it true that the proportioning valve will only really affect the rear drums?
If a system looses pressure, the valve shuttles and stops the fluid to the failing system top keep the operable sytem functioning, as a safety device.
Check to see that pressure is being sent to each system, front and rear alike. pressures will be different of course, but as long as you get action that would be an indicator the valve is not shuttled to one end closing down one system. A RED BRAKE warning light on the dash that is illuminated( after bulb check) is a good indicator that the valve has shuttled and not operating both systems.
Ok.. Ill check that..But could it also be that the master cylnder is a cheap one?
Probably not a defective master, its possible. Probably something you missed.
If the parts store will give you another ,throw it on, then youll know for sure I bet its something else.
brakes
diyou bench bleed master cyl before installing?
| New Disc Brakes but soft pedal | ducrider123 | Suspension - Brakes - Steering | 12 | 07-04-2011 10:06 PM |
| brake pedal hard then soft but hardly any brakes | Wildwestshow | Suspension - Brakes - Steering | 1 | 12-24-2010 07:18 PM |
| Soft Brakes... | S10xGN | Suspension - Brakes - Steering | 13 | 08-24-2009 01:06 AM |
| 79 malibu soft brakes | mikes68493 | Suspension - Brakes - Steering | 5 | 06-12-2007 08:37 PM |
| is it just me or is this an unsafe engine fix? | stonedchihuahua | Hotrodders' Lounge | 5 | 05-16-2003 04:31 PM |
