To soften ride - remove longest or shortest leaf? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2008, 09:18 PM
cboy's Avatar
Last journal entry: Finished
Basic question is...which decreases stiffness the most, removing the shortest leaf you can or the longest leaf you can.
I did a search which came up with only this thread. It seems to say (in entry #8) that removing the shorter leaf(s) in a spring stack will soften the ride more than removing the longer leaf(s). Is this the general consensus?
Always learning...and sharing what I've learned.
Old 09-17-2008, 10:25 PM
countryboytn's Avatar
you can never know to much
Last wiki edit: Practice page Last photo:
Wiki Edits: 3
Looks like the shortest would make it softer, since the shorter somthing is the harder it is to bend.
for example: you have a 2 foot piece of wood, which you can easily bend/break, But if that same piece of wood is 6 inches long, it becomes much harder to bend or break.
hope this helps, and correct me if I'm wrong.
Old 09-17-2008, 11:19 PM
powerrodsmike's Avatar
Wiki Edits: 161
Countryboytn is right.
Remove the long leaf, and you wind up with a spring prone to axle wrap, and wheel hop .
Removing the shortest leaf(s) will soften the ride, and you won't wind up with an unstable rear end from having too flexible long spring set.
You can also cut the rear of the spring just behind the axle clamp. (U bolt plate) You want to leave all of the spring inbetween the clamp and axle..
Mustang guys, (dodge guys too), will add a long half of a leaf spring at the front of the spring pack to give a traction bar effect without making the spring rate too high..
Later, mikey
BE different....ACT normal.
Old 09-18-2008, 06:54 AM
cboy's Avatar
Thanks for the quick responses. That's what I needed to know.
Old 09-18-2008, 02:22 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Sounds like someone is getting ready to take his project out for it's first ride. Or perhaps he already has.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 09-19-2008, 06:48 AM
cboy's Avatar
I wish. Everything is still totally blown apart for prep and paint. I'm getting close to putting the rolling chassis back together and I know, based on some stiffness testing during the fabrication process, that the rear spring rate needs to be softened up quite a bit. So my question here was just in anticipation of when I put the rear end back under frame. Gobs of work yet to come before I can even think about that maiden voyage.
Old 09-25-2008, 07:51 PM
RKkustoms's Avatar
we build stock to kustoms
take the short spring out
Old 09-25-2008, 09:18 PM
life is a temporary assignment
They are right,The short one has to go!!!!! Can't wait to see it Cboy.... Come on man!!! back to the shop
Old 09-26-2008, 07:58 AM
cboy's Avatar
Yup. I AM back in the shop...just not any good pictures to show for it yet.
Old 09-26-2008, 08:11 AM
I was starting to worry about you Cboy... I told my wife you must be very into your work right now.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Leaf springs or Full Air ride? 427v8 Suspension - Brakes - Steering 7 03-14-2008 12:59 AM
leaf spring cutting for better ride? rh88k5 Suspension - Brakes - Steering 1 05-17-2007 04:00 PM
Lower car and soften the ride Michaelbc Suspension - Brakes - Steering 13 10-10-2006 05:46 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
