Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - soldering large guage wires
  #16 (permalink)
Old 07-30-2005, 01:15 AM
malc's Avatar
malc malc is offline
Living At The Speed Of Life
Use a butt bonnector, crimp first then solder, wrap with some insulating tape then slide the shrink wrap over the joint. Twisted soldered wire tends to have "points" that will cut through shrink wrap eventually.
If the soldering is successful the solder will "shine" if not it appears "matt".
If I were doing it in the car IŽd rather not use a butane torch.
Even with a good soldering iron, in car soldering is a pain.
If it is in an area such as under the dash, IŽd just crimp.
