soldering question??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2008, 10:37 PM
hi guys, can you solder aluminum and copper together? i would like to build some heater tubes by turning down some aluminum AN fittings and soldering them into the ends of copper pipe (like you would use for household plumbing). i just don't know if you can solder aluminum to copper, anybody have any idea??? thanks, techron
Old 11-13-2008, 11:09 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
It can be done, that is the way the AN heater hoses connect to the copper heater core in the Blown '73 Corvette. Check my photo album, I believe there is a picture of the passenger side that might show them.
It just shows the AN fitting only, and no part of the copper tube. Sorry.
Old 11-14-2008, 01:16 AM
thanks carsavvy, i like your 73. i'm an old vette guy and am presently building a 64 restomod coupe. most car builders fall down in the wiring and plumbing area (my pet peeve). i've already built my own wiring harnesses to the front and offloaded the current to modern relays. the engine compartment wiring is completely hidden. i didn't look at your pics yet, but i'd like to know the details. is it a simple soldering job???
i was just going to eleminate the heater, but decided to keep it, i fliped it 180 degrees so i could attach heater hoses and run them through the fenderwells at the top of the fenderwell that's where the copper pipe comes in.. i want to have the AN fittings coming through the inner fenders attached to aeroquip fittings to the engine.
so, is soldering copper pipe to an aeroquip simple?? aparrenty you have done it.
where is oldred, he could probably answer this.
give me the spifics on soldering, i know copper to copper, but i don't know copper to aluminum.
by the way, where is lakeside, ca. ???
Old 11-14-2008, 01:40 AM
My 2 cents worth
Wiki Edits: 3
I did not do the soldering, and can not give you any information as to what solder was used. I was there at the time 6 years ago, and don't recall what was used. I do remember it had a light silver look, but I was busy putting together the hoses.
I can tell you it can be done, and it has worked for 6 years now.
Like you asked, where is oldred when you need him most?
There is one picture that comes close to showing it, but it stops at the AN fitting.
Old 11-14-2008, 03:15 AM
My 2 cents worth
Wiki Edits: 3
Lakeside, is a suburb of San Diego, midway to the northeast side of the county, between the mountains, and the beach. It has that 'good home' country attitude I love.
I will make a call in the morning, and try to get a picture of those hose fittings.
Maybe by then we will hear from oldred.
Old 11-14-2008, 05:39 AM
bondo's Avatar
Ayuh,.... That is Not possible....
If you use Steel fittings, Yes....
Old 11-14-2008, 09:29 AM
Aluminum can be soldered (but not brazed) to most metals including Copper. At the moment I can not think of a specific solder that for sure works for this but I am thinking that Harris Al-Solder is for soldering Aluminum to dis-similar metals. Call your local welding supply and tell them what you are doing and have them recommend something they might have. This is not especially hard to do and does not require any high tech tools but you will need a Stainless steel brush that has NEVER been contaminated with Carbon steel, get a new one and don't use it for anything except cleaning the Aluminum.
Old 11-14-2008, 10:37 AM
Last journal entry: More painting pics
http://silfos.com/htmdocs/product_su...ion_guide.html
This site sells a solder that can be used to solder Aluminum to Copper. It also gives some useful tips on soldering/brazing in it's 'how to' section.
Old 11-14-2008, 10:51 AM
I did not want to mention it without checking first but even Advance Auto has a package of soldering/brazing rods of various types that I am almost certain contains a soldering alloy for dis-similar metals. A welding supply should have something on hand and it is a good possibility that it could also be found at a HVAC supply.
Old 11-14-2008, 11:53 AM
wildman1932's Avatar
Dave's hot Rod Shop
It sounds crazy---but a guy brought some solder to our shop and showed how it could be done. The materials are rare (hard to find), a little touchy to use, but can be done.
Dave
Daves Hot Rod Shop KC Mo
Old 11-14-2008, 12:23 PM
i work for a major manufacturer. we use epoxy at all the copper to aluminum joints. heating aluminum tubing will make it weak behind the joint. if you like i will find out what kind it is. Jonathan
Old 11-14-2008, 12:52 PM
thanks jonathan, yes, if you could post what kind i would be interested to know. thanks-techron
Old 11-14-2008, 02:30 PM
My 2 cents worth
Wiki Edits: 3
mcmastercarr.com has technical information for solder on page 3312. I believe you will need a 'fluxed' core solder. Just input 'solder' into their search box, and go to page 3312. It's interesting to read. I did not know there are that many different types of solder available.
Old 11-14-2008, 02:31 PM
Heating Aluminum tube to soldering temperatures should not be a problem. If welding or brazing Aluminum to Aluminum this might however be a concern.
Old 11-14-2008, 02:52 PM
My 2 cents worth
Wiki Edits: 3
The tube is 'copper', and the fitting is 'aluminum', do you recommend a flux solder?
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
