The simple bottom line, it can open the valve faster and higher for a given duration. That makes more power. The lifters can also be much lighter, making the valvetrain more stable.
HHmmm, I like that idea. Higher revs with lower spring pressures. Gonna be a daily driver with an occasional strip pass so I want to be able to rev it now and then.
Higher revs likely, lower spring pressures not likely due to lobe intensity.
How often would someone have to adjust a solid cam. I would think that the only reason would be if the cam was wearing or lifter and then it got sloppy, and require adjustment.
Few things sound as good a solid lifter SBC with a set of headers through some decent mufflers (not loud). The key to keeping solid lifters adjusted is screw in studs with high quality locks.
Vince |
The nice part about solid lifter is the fact that you can vary the valve openings to suit the weather conditions - and actually set intake and exhaust differently. I played around with that a lot in the early to mid '60s with my 406 and 390ci solid lifter HiPo Fords. I still have the old P&G Valve Gapper - but am to the point that a hydraulic lifter/camshaft has enough for my street driving.
Dave W |
The advantages are more power especialy above 6000rpm and more rpm.
Hydraulics are for da GiRlIe MaN .
Thanx folks! I think when all is said and done i will finally try a solid cam. I need to sell my 78 Camaro to fund this this little endevor so i have some time to plan. I'm thinking of starting with a Blue Print 383 short block, adding AFR Eliminator heads, Comp 12-677-4 cam, Stealth Air Strike intake, and maybe an 850 cfm something to be determined.
All going into an extended cab s10 with a TH475 and 4.10 gears. Still dont know what to do about the prop shaft. |
As stated before they are alot better above 6000 rpm. I like them because when you set them, you know exactly where they are at.
None of this "then go another 1/4 to half turn" junk. I agree with the adjustment schedule listed above for racing but in my BBC with ARP locks I only had to adjust it once a year and once it was all broken in it would only be out of adjustment by a few thousandths on one or two valves. That was a solid roller though so it might not apply here. |
| hydraulic cams/lifters | brian12c | Engine | 4 | 03-07-2005 08:46 PM |
| Comp Cams hydraulic roller vs. solid flat tappet comparison | Mad Maggot | Engine | 23 | 02-13-2005 10:29 AM |
| Solid cams vs Hydraulic cams, preference or power? | killerformula | Engine | 17 | 02-03-2005 09:42 AM |
| The New Solid Lifter | DTL504 | Engine | 0 | 05-16-2004 10:41 AM |
| Solid motor mounts? | Trav | Engine | 7 | 10-05-2003 12:41 PM |
