solid cam & lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 06:56 AM
solid cam & lifters
i know you cant mix up lifters. can you put new lifters on a used cam?
Old 08-25-2010, 08:57 AM
Yes you can do that as long as the cam is not worn out on the lobes, What you have to have in mind is that you need to brake the cam & lifters in as they were new... If you do that you shouldn't have any problems. Just be sure to use Quality lifters and brake in oil.
how much hp and torQ will my motor have xycho_wraith37 Engine 11 03-10-2010 01:14 AM
SBC Solid Cam, Rockers Hitting Valve Covers?! ezobens Engine 11 05-01-2007 02:24 PM
hydraulic cams/lifters brian12c Engine 4 03-07-2005 09:46 PM
solid cam and hydrolic lifters? onecoomofo Engine 4 03-29-2004 10:24 AM
hydrolic lifter cam vs. solid lifter cam chevyelc81 Engine 12 09-09-2003 08:38 PM
