Solid Lifters Vs Hydraulics. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2010, 06:22 PM
I aquired a 400 SBC with Crower Solid Lifters. 1.6 Roller Rockers, 5.7 Pushrods, Crower Cam Lobe Sep @ 112 Degrees, Duration at .050 is Intake: 260 Exh :266. Went from a ZZ4 Chevy 350 , 355 HP to this. My question is this: At what intervals do I have to adjust the Solid Lifters? I paid a shop to set the Cold and Hot Lash on them but still noisy or are they just noisy in general?. More so then the ZZ4?. How do I know the lash was set aside from taking their word? Again, what determines the intervals in adjustment. The car is a "Weekend Warrior" . Thanks.
Old 02-11-2010, 06:34 PM
S10 Racer's Avatar
http://www.warsprints.com
Solid lifters will be noisy because of the lash, it's their nature. As far as re-adjusting them, it depends on how many miles you put on it but I would say somewhere around every 3k miles. You will just have to take the shops word for it unless you want to check them yourself.
Old 02-11-2010, 07:01 PM
Solids Vs Hydraulics.
Thanks to you S10. I quess I just have to monitor the engine for unusual noises and Thanks for the 3K answer. I will use it as a "Baseline" & take it from there. Have a good one.
Old 02-11-2010, 07:06 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Lash is easy to set, just a little time consuming. It wouldn't hurt to check the lash yourself that way you know how to do it. When I had my Blazer I put a solid lifter cam in it. At first I checked the lash at every oil change. But I found most never changed so I started checking the lash at every other oil change and at the most I had to adjust a couple rocker arms.
Old 02-11-2010, 11:06 PM
406 bug's Avatar
9.82 @ 139mph
How did you determine the lash, or did the shop determine lash. The lifters should not be noisy. If you know the correct lash, warm the engine up to operating temp, pull a valve cover and check the lash on a given cylinder. If the intake is greater than 18;exhaust greater than 20 , your lash is probably excessive. But Crower is who should be providing you the correct spec., if in question.
Old 02-12-2010, 06:18 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
If were you, I'd install a starter button on the firewall, (for easy bumping over, much easier than disconnecting the coil and having someone man the ignition switch or hooking up a hand held starter button every time), and learn to do it yourself. If your motor doesn't have too much stuff in the way, it's a task that can be done, after some practice, in as little as about 1/2 an hour.
Old 02-12-2010, 01:05 PM
Blazin72's Avatar
Wiki Edits: 19
Or you can roll it over using the crank bolt. You'll get the engine exactly where you want it that way. If the engine has higher compression it would be a good idea to pull the spark plugs first.
Old 02-12-2010, 01:07 PM
F-BIRD'88's Avatar
Yada Yada Yada
set the lash youself. Set tjhe lash using the intake close/exhaust opens method of getting the lifter on the base circle of the cam lobe you are adjusting.
Set the lash .002" tighter than the cam card specs.
Old 02-12-2010, 04:50 PM
Solid Lifters
Thanks to "ALL" for your inputs. I will take it from here. Gives me time to get with Crower on this.
converting hydraulic to solid lifters ap72 Engine 23 10-24-2008 04:06 PM
Solid vs Hyd. Lifters...AGAIN Fastest65 Engine 12 08-26-2008 04:35 PM
whats the best way to set solid lifters. hot or cold? ElCa/monty Engine 4 05-06-2007 05:08 PM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
solid lifters elchevy Engine 0 07-16-2002 07:07 AM
