Solid Motor Mount Question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 07:04 PM
Alright this might be a dumb question but I bought some moroso solid motor mounts and ARP bolts for my SBC 355 and if I put the mounts together their seems to be extra room that the motor could slide forward and backwards or atleast try to. Is this normal or to washers go between the motor mounts? Thank you.
Old 03-11-2013, 06:19 PM
Monday bump
Old 03-11-2013, 06:36 PM
poncho62's Avatar
Wiki Edits: 5
I am not an expert on these things, but I would take the slack out with washers. Is this s street engine?.....If so, I wouldnt be using solid mounts
The Following User Says Thank You to poncho62 For This Useful Post:
Trucknut (03-12-2013)
Old 03-11-2013, 07:06 PM
BigMo's Avatar
The frame mounts are too narrow for the mounts. Either fab a wider piece for the frame side or live w spacers (ie. Washers) in the mount
Old 03-11-2013, 08:13 PM
Landshark928's Avatar
FrankenPorsche
Did you get the right mounts? There are different widths available for the SBC. Washers would not be a great way to fix.
Old 03-12-2013, 12:25 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
I'm with Poncho if it is for a street driven car.Plan on tightening every possible bolt/screw there is from the vibe's.Kind of treating it like a old Harley.
I addition to that is isn't uncommon in a drivetrain with solid mounts the output of the engine to seek and find the weakest link.A example of that is now you have solid mounts and your hooking the car hard and find now your breaking tranny cases needing a midplate.So you fix that problem and then your twisting driveshafts or breaking u-joints.So on and so on.Torque will find and expose the weakest link.The reason why that isn't so on a rubber mount is some of that is absorbed by the mount.
Old 03-12-2013, 05:04 AM
Bonneville462's Avatar
I was always led to believe they are bad ju-ju on a street car... Besides, aren't all new rubber motor mounts inter-locking?
Old 03-12-2013, 06:04 AM
its a drag only car Im gonna email them today. It just seems like their should be a tighter fit?
Old 03-12-2013, 06:08 AM
BigMo's Avatar
Used them on the street on many cars.....advise putting solid mount on tranny too.....never broke trans cases or driveshaft issues....and that was with a 700 horse big block in a Camaro. They do make a rubber isolated mount that has interlock to prevent motor walk if the mount does break. Some of the early Corvette and hi-po mounts had like a interlocking "fork" arrangement that restrained the motor on a hard pull, but still retained the rubber isolation during normal driving.....
Old 03-12-2013, 06:11 AM
No problem with solid mounts on the street. Funny how people put solid frame to body mounts and suspension mounts in their cars but worry about solid engine mounts.
Old 03-12-2013, 06:15 AM
delete........
Last edited by Bonneville462; 03-12-2013 at 06:18 AM. Reason: Off original thread starters topic..
Old 03-12-2013, 02:14 PM
1badLemans's Avatar
You have the wrong engine mounts from moroso. Im currently solving this issue on my camaro due to switching from small block to big block. Go to their site and look for the ones that are narrower, they have the A and B measurements and part numbers there. Or of course switch the frame mounts to fit the moroso mm you have now. You "could" shim it but definitely not the correct way to get it done.
Old 03-12-2013, 06:18 PM
An old technique is to run a turnbuckle from a strong bolt on the engine to either a bolt or eye bolt in the firewall or to an available location or bracket on the frame to prevent fore/aft engine movement.
Once the engine is located where it needs to be, then the turnbuckle is rotated to take up any possible forward or backward movement on the mount then it's locked in place with a nut from either or both ends. Thus the engine cannot slide about in large or an elongated mounting hole.
Bogie
Old 03-12-2013, 09:43 PM
1Gary's Avatar
Bogie
Yep,we cabled them yrs ago.
Old 03-13-2013, 10:57 AM
Measure the width of the frame mounts then go to Moroso : Category Display Get the mount that matches the width of your frame mount. Here is some frame mount and motor mounts for 67-69 Camaros. Camaro Engine
motor mount question 87fubar Hotrodding Basics 3 05-12-2011 05:23 PM
solid motor mounts/solid tranny mount carnahan Engine 6 03-25-2011 11:14 AM
Motor mount question cyberdork Hotrodding Basics 5 03-21-2011 08:03 PM
Solid motor mount Question greenmoonshine Engine 9 06-13-2009 08:49 PM
Motor mount question raidmagic Engine 6 10-23-2004 05:27 PM
