solid motor mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2012, 02:13 PM
solid motor mounts
ok so im building a 570hp 383 stroker for a mud truck, im wondering what the pros and cons are for them, i have heard that solid motor mounts will crack your block from frame twist. this motor is goin into a 79 k10 pickup 4x4 with a 3 speed with a granny low. im not sure how much those frames flex so thats why i listed it.
Old 04-08-2012, 04:27 PM
T-bucket23's Avatar
Wiki Edits: 26
Solid mounts are known to crack bell housings. You can get rubber mounts that have safety's built in that are a better choice
Chet
Old 04-08-2012, 04:43 PM
so basically they allow a little bit of movement then lock up like a solid while dapening vibrations? what about the polyurethane motor mounts? what difference do they make? and are they any better?
solid motor mounts 69 work in progress Engine 10 07-20-2011 04:52 AM
solid motor mounts/solid tranny mount carnahan Engine 6 03-25-2011 11:14 AM
Solid Motor Mounts ss crazy Engine 8 09-19-2003 07:15 AM
Solid Motor Mounts black66 Engine 6 05-16-2003 11:14 PM
solid motor mounts bigbodymerc Engine 11 09-25-2002 11:41 PM
