Solid roller to hydraulic roller cam questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2009, 07:03 PM
Greetings
The car is an 87 Trans Am GTA with non-original motor,the 305 was swapped out for a 350,unknown year.
The engine is not a factory hydraulic roller block and at present has a solid roller cam.I am wanting to put a hydraulic roller cam back in.
What problems am I going to encounter?
Thanks
Old 03-23-2009, 08:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Should be fairly straightforward, I'd think.
Be sure to remove any oil restrictors that may have been installed for the solid roller.
Valve spring pressure is likely too much for what's gonna be needed w/the juice cam.
Tuning will be needed, probably. Distributor advance/timing curve, carb jetting.
Depending on your set-up, the carb and intake might not match the juice cam, but that is an unknown until more is known about what you now have.
Reducing Valve Lash on Solid Roller - Is It Ok To Do? leejoy Engine 13 12-19-2008 11:11 AM
Valve Lash & Cam Operation - Basic Questions leejoy Engine 5 12-14-2008 06:13 PM
Soild Roller Or Just Roller Maybe Just Soild Cam? Best For Me tiresmoke55 Engine 21 08-22-2007 07:10 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 11:29 AM
Solid lifters on hydraulic cam? ratlover Engine 5 09-29-2004 10:22 AM
