You really need to know the vacuum level @ idle first before you can really go anywhere with it. I would use the secondary throttle adjustment to get the idle air initially set this will help get air into the engine without having to expose the idle transfer slots on the primary side which would affect the power valve function too but you'll have to do this with the carb off the manifold.
what duration is the cam???
get it running first. check the vacuum at idle and during highway driving and during lite throttle driving around town. With bigger cams, I typically run a pv at 1/2 the idle vacuum, but make sure the pv doesn't come on while just driving down the highway. you will get better throttle response if the PV is a little bigger, but mpg will go down. A 4.5 or 5.0 normally does the job with bigger cams. a cam like yours will need lot of initial ignition timing. 20 to 25 degrees. |
PV's are $6 a pop, pays to buy them as you need them as they will stiffen w/age. |
| acceleration flat spot in carb. | corvettetonybone | Engine | 17 | 04-13-2013 08:31 PM |
| Modifying Holley baseplate so power valve references manifold on s/c motor | blownS10blazer | Engine | 5 | 09-05-2008 10:21 PM |
| SBC Solid Cam, Rockers Hitting Valve Covers?! | ezobens | Engine | 11 | 05-01-2007 01:24 PM |
| solid flat tappet v/s hydraulic roller | 406 ss monte | Engine | 8 | 10-31-2006 08:29 AM |
| Secondary Power Valve | Blazin72 | Engine | 1 | 04-29-2006 03:46 PM |
