Solid roller valve lash adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2004, 08:05 PM
snod83's Avatar
Alright, i have done hydraulic lifters and hydraulic rollers, but never solids. I know that I am to put a feeler gauge between the valve stem and rocker arm tip, but do I tighten the nut until i have tension in the pushrod, or just until all of the up and down movement is out of the pushrod... Its on a small block chevy by the way..
Thanks again guys,
Ryan
Old 05-10-2004, 08:10 PM
poncho62's Avatar
Wiki Edits: 5
Just until you take any movement out of the feeler guage.
Old 05-10-2004, 09:08 PM
lonewolf3197's Avatar
Chief Petty Officer, USN
Last journal entry: My Monte Carlo
Your cam card should give you the proper clearence. Don't use the push rods for a zero lash reference like with a hydrolic cam. It's all in the feeler gauge
