Mouser Electronics has a good selection....But they cost about 30 times more than an equivalent electromechanical relay.
I've seen them cheap (like $5 ea.) at a local industrial surplus store, but they were used and in unknown condition. |
"Mouser , Digi-Key or Allied Electronics"
I use those regularly for stuff but was more curious which relays people re using. When you spend thousands on an extensive car build a few extra dollars for a solid state relay is not a big concern. I see people dump $50k in a car and they won't spend an extra $100 for the better tires. Some one turned me on to these. I may give them a try. I think a 100amps with 240 amp surge will handle the load. |
That's a good deal. But I would still think twice about using solid state relays in place of standard electromechanical relays in an automotive application. The reason being; when a standard relay is off, it doesn't draw any amperage at all, but a solid state relay 'leaks' current when off. This might only be 10 or 20 mA, but if you use 8 or 10 relays in the car, this leakage current can add up to the point that it could run your battery down if the car is left parked for more than a few days. I believe that is the primary reason they aren't used in the automotive industry.
Just my $ .02 |
I am still running them through a high current master and will be fused for their application so that won't be an issue.
The electrical system I am organizing is not completely conventional. It is going in a Pantera and I have a lot of "other" items. Trans fluid pump, radiator fans, electric power steering pump, etc. The car originally had a fuse box under the dash but I am actually dividing it into to fuse banks; one in the front trunk and one on the rear firewall (mid engine car). |
Artificial Intelligence is no match for Natural Stupidity Chet |
try looking in mcmaster carr or grainger they both carry ssr's
Hella makes the smaller "bosch style" four pin solid state relay Hella and Hella2
I always use good, name brand, bosch style relays when wiring a vehicle and have never had a problem with one going bad. I can't see the justification for the additional expense of the solid state relays. They do look somewhat cool and operate quiet, but I don't have a disposable income. |
| 14014145 relay TCC ? | fast68 | Electrical | 0 | 10-04-2009 09:47 AM |
| Trying for a NEW law in Washington state?? | Bad Rat | Off-Topic | 0 | 02-17-2007 01:55 PM |
| Power Seats | MI2600 | Electrical | 4 | 10-06-2005 04:55 AM |
| Relay issue? Starting problems | 2ManyCars | Electrical | 4 | 08-06-2005 04:13 PM |
| Help Wiring A Relay to A Dash Switch | horvath | Electrical | 6 | 03-06-2005 01:58 PM |
