solid straight axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2006, 04:21 PM
looking for info on early gasser solid front straight axles. Where can i buy axles springs and steering gear box and not from Speedway the axles are weak and tend to bend on a 3000 lb. car. the car is a 37 olds coup. with a 468 big block any info will help
Old 06-19-2006, 05:43 PM
Wiki Edits: 49
I'd check your local junk yard for Ford Econoline vans. Thats what a lot of people used back in the day.
Old 06-19-2006, 08:54 PM
BOBCRMAN@aol.com's Avatar
MAS (Minnesota Auto Specialties?) regularly advertises in the popular Rod rags. They offer several types of straight (tubing) axles. I have used the 4" drop with Chevy spindles. Very stout, well made.
Old 06-20-2006, 08:23 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
In the late '60's I put a CAE tube axle in my '65 GTO, they were built super tough. CAE used to be a big part of sprint car racing, you could order any width.
I did a quick search for them and can't find anything, they may have gone the way of many of the old manufacturers; maybe some of the roundy guys here know something about them.
Old 07-09-2006, 07:35 PM
Try roadsters.com or peteandjakes.com. They have a lot of hotrod axles. Goodluck!
Old 07-09-2006, 08:39 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
TRy Chassis Engineering..... www.chassisengineering.com
hydraulic cams/lifters brian12c Engine 4 03-07-2005 08:46 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
The New Solid Lifter DTL504 Engine 0 05-16-2004 10:41 AM
Solid motor mounts? Trav Engine 7 10-05-2003 12:41 PM
