solution to lack of fender problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2006, 02:13 PM
Higirl's Avatar
Most of you guys saw my post about Ca law and lack of fenders. I did my research and yes I can be pulled over and cited and it is a fix it ticket. Since I intend to drive my roadster quite a bit I decided to look into adding fenders. I saw the yellow coupe in American Graffiti and liked the fenders, I didn't think it distracted too much from the overall lines of a 32.
I subsequently have found and seen a few photos of different Deuces with those bobbed fenders, all looked pretty good to me.
I saved one and put it on a webpage for you guys to see it. Here is the link:
http://www.southerncaliforniacampers.com/deuce.htm
The question remains: where can I buy these bobbed fenders? I emailed a couple of owners listed under the photos but the only one who actually replied said his fenders where home made...
Old 07-25-2006, 02:21 PM
1939d2/s10's Avatar
fenders
I wonder if on the fronts you could use motorcyle fenders modded ? The rears kinda look like chevy 1936 p/u fenders,I know R&R fiberglass here in Tn reproduce the truck fenders.Geez wish I had your problems.... Good Luck ,Johnny
Old 07-25-2006, 02:28 PM
302 Z28's Avatar
We have one of our club members who has a clone of the 32 in the movie. I will ask him what he used for fenders.
Vince
Old 07-25-2006, 02:35 PM
Wiki Edits: 31
the guy my dad bought his '72 C10 from has a '32 Roadster, and it has what looks like trailer fenders on the rear, it looks ok like that. I'll get a better look at it thursday, he'll be at the cruise In with it then.
Old 07-25-2006, 02:39 PM
Last journal entry: Free tires
I talked to my local rod shop about fenders awhile back, he suggested motorcycle fenders on the front, on the rear he said he could no longer find bobbed fenders and buys whole rear fenders and cuts them down. He said they really aren't that expensive whole and you can get the length you want by cutting them.
Old 07-25-2006, 03:00 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Buy fiberglass fenders for the rear of your car.......cut them down and bob them to suit your taste.
Old 07-25-2006, 05:55 PM
nissan's Avatar
Last journal entry: 1930 chevy ratrod pick-up
we had a 31 ford coupe an used harley fenders on the front an curved flat sheet metal with rod welded around the edge for support. it won shows.
Old 07-26-2006, 02:09 AM
Higirl's Avatar
Vince
Vince you rock and all of you guys who are helping ... I found that T-performance sells fenders for T-Buckets, both front and rear, I wonder whether the front ones would work, maybe I will give them a call and ask...
OK, better go to bed now it is real late, I went to a very cool swing dance event tonight and danced my old 1930's shoes off, some of the best Lindy Hop dancers in the country were there... Can't wait to get my car, it is going to make going to the Derby that much more fun!
Old 07-26-2006, 10:27 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Good to see you are getting sorted out here..I have seen all kinds of things used for fenders..even can make your own if you like..
www.metalmeet.com and reas and study on metal work in our data base..also one can do a search of google images and come up with all kinds of pics that can help with ideas..
Sam
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Temperature Sending Unit problem Centerline Engine 3 11-12-2004 05:13 PM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 07:27 PM
Metalshaping/Panel Relacement '34 Chrysler fender Randy Ferguson Body - Exterior 12 05-31-2004 10:37 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
