-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Which solvent to clean paint gun? (http://www.hotrodders.com/forum/solvent-clean-paint-gun-175240.html)
cyberdork 03-26-2010 07:39 PM
Hi all, new member and new DIY home painter. I'm painting my motorcycle with a urethane primer and an acryllic urethane base. What solvent should I run through the gun to clean it out?
Thanks
trees 03-26-2010 07:57 PM
Lacquer thinner works for me. Regardless, you can't over clean the gun. I almost totally disassemble mine every time I clean it after not cleaning one good enough several years ago. When poly paints set up in your gun, you have got your work cut out for you.
Trees
cyberdork 03-26-2010 08:05 PM
Thanks alot!
Beenaway2long 03-31-2010 09:10 AM
Brake clean from Walmart. $1.38/can
Melts the cruddy paint right out. Then wash with laquer to get residue out. Killer on clear.
Torque454 04-03-2010 10:46 PM
My boss cleans his guns with lacquer thinner and then leaves FRESH clean lacquer thinner in the gun and hangs it up on a rack.
