Which solvent to clean paint gun? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2010, 08:39 PM
Hi all, new member and new DIY home painter. I'm painting my motorcycle with a urethane primer and an acryllic urethane base. What solvent should I run through the gun to clean it out?
Thanks
Old 03-26-2010, 08:57 PM
Lacquer thinner works for me. Regardless, you can't over clean the gun. I almost totally disassemble mine every time I clean it after not cleaning one good enough several years ago. When poly paints set up in your gun, you have got your work cut out for you.
Trees
Old 03-26-2010, 09:05 PM
Thanks alot!
Old 03-31-2010, 10:10 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Brake clean from Walmart. $1.38/can
Melts the cruddy paint right out. Then wash with laquer to get residue out. Killer on clear.
Old 04-03-2010, 11:46 PM
My boss cleans his guns with lacquer thinner and then leaves FRESH clean lacquer thinner in the gun and hangs it up on a rack.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 03:20 PM
Low volume Low pressure paint gun 35olds Body - Exterior 27 06-28-2006 07:48 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 07:31 AM
1st painting nova33 Body - Exterior 19 06-16-2003 11:05 AM
