The problem was probably a combination of using the medium reducer
and the relatively cold temperatures; and 30 minutes just wasn't enough time for all the solvent to outgas in the lower (1st) coat of clear. Using a fast reducer, or if it was warmer, or waiting longer between the clear coats would have prevented the soda pop effect....
Curious why you wouldn't use the reomended "DT" reducer in that clear?..
http://www.google.com/search?sourcei...ner+dt+reducer |
you needed longer than 30 minutes especially after the 2nd going to the third
TWO mistakes in my opinion. One not using the recommended DT thinner. Two not waiting long enough between coats is more than likely the real culprit. FWIW, IMO the PPG DCU2002 clear is a much better product.
Vince |
asked the ppg platinum paint seller today and they said jr is used instead of dt all the time with no probems, guess its cheaper and suffices. I think i discovered my probem tonight though. i had just purchased a devilbiss dryer system a few days prior didnt think to check the dessicants since i hadnt really used the compressor that much but when i pulled the container apart water just flowed out and the dessicants were white and the indicator was pink. That would explain why i didnt have any problems a few days prior using the same stuff, temp, and recoat time. changed the dessicants and trying to spray it again tomorrow, will update. Thanks for the advice
never use a cheaper reducer.
need to wait longer going into the 2nd the 3rd coat. PPG paint seller,LOL!!!!!!!!!!! maybe it was the Dessicant maybe not? |
Problem solved!!! but at the expense of my friends paint job. So a week later my friend is getting ready to paint his car in my garage. He was using a totally different paint system and gun. As he began spraying the clear just as i had done we noticed the one million fisheyes begining to appear after the second coat. So then I narrowed it down to what was common the compressor/dryer. I checked the dessicants we had just replaced and they were pink already and the filter had a hand full of water even after it was drained before he started shooting. I opened the purge valve and had him pull the trigger and water formed in my hand as he sprayed. We junked the dessicants and put two rolls of toilet tissue in the canister and the air was dry as a bone and he finished the job with not too much damage. So the problem is that my air line is level all the way to the filter and letting the moisture form the compressor come right to the gun. Not sure why there is so much moisture on a cool dry day any ideas?
| Solvent pop | larrym | Body - Exterior | 4 | 02-26-2010 12:46 AM |
| Solvent Pop ?? | Polish Painter | Body - Exterior | 20 | 06-24-2008 07:48 PM |
| Solvent Recycling | mike6845 | Garage - Tools | 7 | 06-03-2008 04:26 PM |
| Got solvent-pop. What to do now? | roger1 | Body - Exterior | 22 | 07-04-2005 07:06 PM |
| Tank Solvent, What is the preferred solvent? | RAW | General Rodding Tech | 25 | 04-16-2004 12:51 AM |
