Some BBC questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2010, 03:00 AM
Some BBC questions
First off, I have a stock 74 454 short block. I used heads off a 78 454. The heads, rocker arms and push rods are all from the 78. They are all matched together, the same push rod is with the same rocker arm on the same valve it came off of. However, i'm using the 74 cam and lifters which were not removed so they are still matched. The only mis matched point is the lifter to push rod contact point. Is it going to matter that i used push rods from a different engine?
Second, I'm ready to install the intake if the push rod situation isn't an issue. The intake is a stock cast iron qjet intake. It was left out in the rain, so there is rust inside the intake. Is that going to be a problem? Its not flaking off or anything, just has colored the intake. Ive got it soaking in a sodium hydroxide (lye) and water solution (similar to hot tank solution) but i think its a bit weak. Ill rinse it off tomorrow and dry it. Do i need to dip it in a stronger solution or just clean it up and install it?
And lastly. Since this engine is used but has been sitting for quite a while (has new timing gears and gaskets but thats it) should I use a special cam lube? (the ZDDP additive i keep hearing about). And whats this about using rotella oil? I was planning on using it, its supposed to have more additives that are better for the cam if i remember right.
Thats it for now i think.
Old 02-18-2010, 05:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The push rods will not matter- as long as they're the correct length and diameter to match your set-up and guideplates.
For "re break-in", while the intake's off, you can reach in w/a small brush and apply break-in lube to the cam. Lifter feet as well, BUT just motor oil (not break-in lube) on the lifter body. Be real sure the lifters are free to rotate.
Put a dab of break-in lube on the p-rod ends and valve stem and rocker arm tip. Also coat the pivot ball and rocker arm where they touch.
Add a dose of ZDDPlus, etc. to the oil before start up. Prime the oil system. There's been a recent post about what oils still have the good stuff, I don't have it at the moment, but you'll see it.
As long as rust isn't able to flake off, what you're doing is probably as good as most inexpensive treatments that can be done at home for ridding the runners of rust. Might take a stronger solution if you want to get it all. I'd run it as-is, I do believe.
Good luck.
PS- Don't forget to give it 40 degrees! lol (kidding...)
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 12:44 AM
Going from BBC back to SBC(2) will have questions... Bumpstick Engine 4 09-20-2005 09:15 AM
ANSWERS TO COMMON QUESTIONS -- PLEASE READ BEFORE POSTING Jon Hotrodders Site Suggestions and Help 0 07-07-2005 03:58 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 03:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
