Some ideas on shooting big panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2013, 07:28 AM
Here is one way to handle spraying big cumbersome fenders that are all one big welded unit. The inside and outer wheelwell are all body color, so painting these things can be a bit difficult. They are very hard to lay out on saw horses as it is not very square with bulging wells. So hanging up is probably the best way to get nice wet edges all around. Hope this can help someone down the road.
ID:	92466   Click image for larger version
ID:	92474   Click image for larger version
ID:	92482   Click image for larger version
ID:	92490   Click image for larger version
Old 10-28-2013, 07:46 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Those 55 fenders are looking great,,I also hang mine and I try to get them at same level from the floor, and don't hang the fender from the front hang it from the top . it seems to keep the bottom section from turning out a lighter shad especially with metaliacs. may just be in my head but it makes me think it works,
Old 10-28-2013, 07:58 PM
Faith - Respect - Trust
Good call Dennis, that's the only way to do it properly...I've also have it set up so I have hooks on the ceiling and on the floor (the floor hooks are almost like the old pots they put into a floor for pulling frames...but smaller) so I can suspend the part from the ceiling and anchor it down on the floor. Nothing pisses me off more than trying to paint a little part or a light fender and it's spinning and flopping around in the breeze from the paint gun. I get a much more accurate amount of paint on, I have less problem with not getting edges....and my favorite...when I'm done, my left hand isn't the color of the parts I painted because I had to hang onto them.
This way I can use regular mechanics wire much more effectively as well. If your painting a lot of pieces on a frame off, you'll know what I mean and...this works great.
Ray
Old 10-28-2013, 09:27 PM
Ray
Yeah I know what you mean about parts moving from the gun as your spraying. What I do with the small stuff when hanging from the ceiling, is I then hang another wire from the bottom of the part, then hold that wire as I spray, and it keeps that part from moving and I don't get paint all over my hand.
Old 10-28-2013, 09:34 PM
When I hang doors this way the bottoms want to lean toward the inside making the painting of them very hard because your trying to spray on an extreme inside angle. What I do is get something heavy, like an old battery, then run a brace to the inside of the door until it is hanging at a 90 degree angle to the floor. So this way you keep the gun at the same angle from the top of the panel all the way to the bottom, and this does help keeping all the color uniform right to the very bottom edge.
Old 10-28-2013, 09:51 PM
Good salution. Looks good
I have a set of saw horses I made that are about 24 inches high and about 4 feet long. I can attach a verticle upright on the end which will support the fender in the verticle position as it would be on the car which has also worked well for me.
It also allowed me to sand the fender without mounting it on the car.
John
Old 10-28-2013, 09:58 PM
Guys, these are all good tips and pointers, need is definitely the mother of invention...I can just remember having the paint booth loaded wit parts from the size of small bracket to a pile of washers...I hated it, not the painting part but the hanging and how hard it was to get everything even...this site has given me more ideas to make my life in the booth easier...and a better finished result....gotta love it.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
John long (10-28-2013)
Old 10-28-2013, 10:19 PM
I do this method too but I still don't think it works well. The part still ends up blowing around, just not as much. In fact I don't plan on hanging anything again unless it's a real heavy part.
Old 10-28-2013, 10:28 PM
You can hang the door from the ceiling and rest the bottom on a support to keep them vertical but steady. This is not the "right" way but is another way.
Old 10-29-2013, 08:11 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
i have rollers made to mount things to. everything in my shop is on wheels .
Name:	door ready.jpg
ID:	93858   Click image for larger version
Name:	fender ready.jpg
The Following User Says Thank You to shine For This Useful Post:
John long (10-29-2013)
Old 10-29-2013, 09:18 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I spray all my bumpers hanging from the ceiling.
the trick is to have 3 separate supports from 3 very
different angles, spread way out.
You don't want the supports from straight above.
That way it doesn't sway.
Sleeper Ideas for a Chevy Big Block 427 eby3 Hotrodders' Lounge 34 04-07-2013 07:32 PM
1936 chevy truck interior panels help ideas 1937MoPar Interior 0 01-08-2012 01:58 PM
ideas for big block truck build boatanchors Engine 12 11-16-2008 08:20 PM
New guy with big ideas Gelphish Introduce Yourself 1 06-28-2005 10:07 PM
Shooting panels individually unstable Body - Exterior 3 05-23-2004 09:00 PM
