Some lifters compress easy? should I worry? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2010, 04:26 PM
I was adjusting my valves [Hydraulic lifters] and I noticed that some lifters were easier to compress [while pushing on the back of the rocker arm] than others. I was careful to get the zero lash and go 1/2 turn from there.
Just a note: This 351w runs great and I never had a valvetrain issue [noise or anything else]. All the preloads were exactly the same before I went through them again.
This is a Comp Cam valvetrain.
The engine has been sitting for a month and I wonder if the valves that were open bled down the lifters. I didn't take note of what valves were open during this time.
I am thinking that while the engine is running all lifters are properly pumped up and working well.
Am I worrying for nothing?
Thanks
Lou
Old 12-04-2010, 04:42 PM
ericnova72's Avatar
More for Less Racer
You're worrying for nothing, you have it figured right . The open valves bled down some of the lifters.
Old 12-04-2010, 04:47 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Thanks
Lou
I wouldn't worry about it as stated it happens, Should be just fine.
They should pump back up.
Cole
Old 12-04-2010, 05:53 PM
Great! thanks guys.
Lou
engine lifters are making a ticking noise watchdude1 Engine 18 12-23-2010 04:07 PM
China Retro Hyd Roller Lifters!! BOBCRMAN@aol.com Engine 1 09-01-2009 05:18 PM
Lifters pumping up? Custom10 Engine 4 07-02-2009 11:39 PM
CTSV or LS7 lifters ap72 Engine 2 01-05-2009 07:41 PM
Broken easy out!!! Now what? 7dcrzr Engine 44 09-24-2008 05:32 PM
