Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Some more ideas for the garage
Old 01-23-2004, 10:53 PM
BstMech's Avatar
BstMech BstMech is offline
NYOFP4RJ3CHRIS
Re: Some more ideas for the garage
Originally posted by Kevin45
Make sure the lighting is on separate switches and circuits from the outlets. This lets you light up just a portion of the garage and prevents the lights from going out all at once. It also keeps the lights on when you cause a problem with an outlet circuit. Kevin
If the garage is already built and the wiring obviously in place, couldn't you use GFI outlets? Or are they not rated at a high enough amperage for running tools and equipment used in a garage?
