Some one please Explain the differance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2005, 10:14 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Will someone explain the differance between a full spool and a mini spool to me? Thanks
Old 03-27-2005, 10:22 PM
montea's Avatar
tryn to learn
i think a mini spool fits inside the carrier where the spiders are and a full spool replaces the whole carrier?
somone please correct me if i am wrong
Old 03-27-2005, 10:28 PM
You are correct. Perfect description.
Old 03-28-2005, 02:57 AM
tbirdscott's Avatar
stuff'n things'n whatnot
Hmmm always wondered about that aswell.
Old 03-28-2005, 04:16 PM
Bowtie or Die!
Duh makes total sense now! Thanks guys!
Old 03-28-2005, 04:35 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Pic and info on a Ford 9 inch full spool.
Pic and info on Ford 9 inch mini spool.
Old 03-28-2005, 07:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
wow... sounds clear
Differance Between Relays PU70 Electrical 3 02-26-2005 08:44 AM
Differance between 305's? Mike_82 Engine 2 10-20-2003 10:53 PM
Truck blocks vs car blocks whats the differance? Jag Daddy Engine 14 05-31-2003 11:12 AM
Can anyone explain this?? HotRodMan Engine 9 10-05-2002 07:32 PM
explain lockout converter??????? doncase Transmission - Rearend 2 08-27-2002 12:46 PM
