hi andi i would suggest using the L98 heads with a little porting they can put out 400hp they flow at 195 cfm stock. or find at set of 5.7 vortec heads 227 cfm stock they can do it with no porting but you'll need a aftermarket intake only about $150 . both sets of heads can 350hp with no sweat just get the springs for that lt4 hot cam and you should be good to go .
and with the heads in my previous reply your compression ratio would be about 10:0:1 pump gas safe .
CARS, thanks for your reply. From what i recall the F-body 350 heads aren't that good of a head, maybe you were referring to the L98 Vette head, or maybe i'm just wrong =)
At any rate, as stated in first post i do have AFR 195 heads and a MiniRam intake kicking around, so i'd rather use these, than get the heads (i just got the shortblock, remember?) and spend time on them with porting. What do you think? |
i was referring to corvette . what is the cfm flow rating on your heads ? and i'm not 100 % positive that the lt4 cam will fit any roller motor i think in only fits lt1/lt4 and the zz4 .
i looked up the specs and the heads you will work fine for 350hp and a lot more . i was not familiar with afr heads before. and like i said not sure on cam fit you could go with a compcams roller cam instead .
thanks all the same, but i'd rather have some input from people who have experience with at least one specific of my combo.
at any rate, i know for sure that the Gen I (SBC) & II (LTx) cams are the same, at least for the rollers and not considering the dowel pin. also, yes - i would venture to state the range for AFR 195 heads just starts at about 300-350hp
my brother has a 350 with 380hp with vortecs and they flow at less cfm but maybe the way they flow is different ? you my try contacting F-BIRD'88 he seems to know a'lot about sbc and how to get the hp out of them .
ok some more specific question here:
i heard some of the early 1pc blocks are prone to cracking, anyone on this? how is the L98 bottom end gonna hold up to 6krpm without balancing? and do you think the AFR 195 are on the big side for this build? thanks! |
We will start with the 195's. you do not need a lot of head to do what you want to do. I am sure the 195's have at least 2.02's. You could gasket match your heads an intake an that should be enough. Yes, they are on the big side. But porting them out will just make it worse. All you will be doing is handing them money.
The lower end is going to do ok with around 6000 rpm's. But, you need ARP bolts in the connecting rods. The lower end needs to be gone through an done right. Would be nice to balance the lower end. All your parts need to work together or they will not compliment each other an will work against each other. That is why you need the right combination. I can not comment on anything else. Because you have not told us anything else about your engine. |
Bowtie man, thanks for the input. Actually i will accept any good power below 6krpm i can get of course, the 350hp was just a minimum, anything higher that can be done on a rebuilt short block is fine with me i guess
![]() I was assuming the same concerning the heads, thanks for clarification there. I'll go and measure the valve sizes next time i get to the garage. I did already CC one port / chamber and i got 67cc for the chamber, 197 for the intake and 66 for the exhaust runner, to make sure what i got. From what i gathered, the stock L98 dish pistons are 12cc, so if piston to valve / head clearance is fine, the felpro 1094 should make a good squish clearance. I might have the block resurfaced slightly, but min. squish i'll get is somewhere between 0.35 and 0.40. The arp rod bolts would be a nice insurance i guess. I would have that done by a machinist. What do you think about the mains? Do i need an align hone when getting better studs/bolts? Just trying to get a cheap bottom end build for now that will hold up for a few seasons (maybe 10-20kmls). Any other input? Go ahead, i welcome it ![]() Thanks again Andi |
well well... like so many times before ... life got in between ^^
so i'm still working out details for this build and i have hopes of completing it before summer starts ![]() i recently came to the conclusion that by retaining the 12cc dished pistons (pre-90 L98 had these for the lower CR) I'd have a hard time setting up a decent CR and squish. so.. i got the idea of putting in a 94/95-up LT1 bottom end, since it's got flat top pistons and in general is lighter, stronger and said to be balanced a lot better than the L98/GenI bottom end i have. any input on this is welcome ![]() another question i have is concerning milling the AFR heads i have.. the 67cc chambers are too big. i'm considering getting the L98's block deck checked and straightened if needed, so whatever deck clearance i will end up with will dictate my need for HG and chamber size to reach the desired CR. |
Just rebuild it 30 over with -5cc flat tops. get the block decked so you end up with a net
.040" quench clearance. EG: .028" gasket .012" deck. The heads are fine as is. The cr will be 10:1 The GM LT4 Hot cam will work well. There are many ways to juggle that and many gaskets to choose. Do not under gear it. slowing down a cammed motor does not work well. Cammed motors need rpm. the Mini Ram is not a low rpm induction system. It wants rpm. The exhaust system will make or break it. |
| 383 Build Questions | ERacerX | Engine | 7 | 06-14-2010 10:04 PM |
| newer rodder want to build a nice 383stroker in future. | tabs@cox.net | Introduce Yourself | 2 | 04-18-2010 06:44 PM |
| Idea for a future big block build | RamAirZ | Engine | 5 | 09-04-2009 05:01 AM |
| 350 build questions | belly_up | Engine | 10 | 02-13-2009 06:23 PM |
| 200-4r experts - build questions - Which core is best to build on? | Warrant | Transmission - Rearend | 7 | 10-09-2007 07:36 PM |
