Some sort of tiny gm torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2013, 10:31 PM
I have a friend who has intalled a little torque converter that he claims is a stock gm. I have no clue where this thing came from. It's approx. 8" and he doesn't know what flexplate to use on the back of his 350 to hook this thing to his engine. It's in a th350 or powerglide anybody please help.
Old 03-28-2013, 10:54 PM
BOBCRMAN@aol.com's Avatar
Small GM is a Vega/Monza convertor. Used to be the econo setup for street/strip racing back in the day. A very weak convertor that baloons if power braked on an engine with torque.
Next smaller is Opal. Drill your own mount pattern.
Tiny tiny solvent pop? brimcp99 Body - Exterior 25 05-03-2011 08:03 AM
4l60e torque converter clutch torque capacity rx191 Transmission - Rearend 1 04-05-2011 05:03 AM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 07:47 AM
Torque Tube Suspension (sort Of) BillyShope Suspension - Brakes - Steering 1 12-18-2009 04:03 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 08:52 PM
