Some Starter Issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2005, 08:04 AM
Some Starter Issues
I was wondering if anyone knows engine blocks real well, so here goes.
I have a 1979 nova project under way. 350th transmission with a pre 1975 350 v8. I always thought that all chevy engines ran with the 168 tooth fly wheel and the appropriate starter, turns out (after alot of asking around) that I should try the smaller 153 tooth flywheel and change the starter. Well it worked Like a charm, it turns over like a 2005 car. I was just wondering why this would be, I thought that flywheel only went on the old powerglides. This may just be a silly young person question that I am over looking though .
Oh and when I changed the flywheel I put it on backwards and had to take the transmission back off AGAIN Thats a good move by me
Old 05-04-2005, 08:18 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
flywheel
You can get both flywheels on 350s. The 400s come with the larger and the 283 with the smaller. The older 400s do not have the straight bolt pattern for the starter. You have to drill a hole and tap it. Especially if you want to use a mini-starter. I am going to check for a staggered bolt mini-starter.
Old 05-04-2005, 08:32 AM
bet on black's Avatar
hotrodder 4 life
what is the best way to figure out what flywheel you have with the engine/tranny already in the car?
i bought the engine/tranny already built. it is a 350 bored/stroked to a 385 with a th350 tranny. it cam out of a 78 camaro, but i have not idea if it was the stock block. it has both starter patterns on it. the starter from the 305/th350 that was in my 77 nova before the swap, grinded and died soon after putting it on the new motor.
Old 05-04-2005, 09:44 AM
you can get a stock mini starter with the staggered bolt holes, 95 3/4 ton pickup with 454, or some 4.3 had them also.
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 06:47 AM
Starter woes Again dollybud Electrical 11 09-01-2004 04:16 PM
starting issues...battery or starter? 79454 Engine 6 10-25-2003 04:10 PM
Starter Solution dollybud Electrical 0 09-30-2003 06:42 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
