Somebody can help me? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2005, 11:44 AM
1300
Somebody have idea, how make from’59 Cadillac extremely high-performance Hot Rod with all-wheel drive?
Old 02-11-2005, 10:42 PM
Last journal entry: Some pics
The car would have to set up alot higher. Because the transmissions and transfer cases that take the type of torque these engines produce are not small. If you are doing it for greater performance, it won't perform better.
Old 02-12-2005, 04:31 AM
1300
And more in detail can tell?
Old 02-12-2005, 08:05 AM
Tazz
I got ans idea...
measure the caddy's wheel base and find a 4X4 that has the same wheel base and switch frames and all....you'll have the all wheel drive and it was already made to do the job...just switch them out....well...what do you think?? I have seen it done with smaller cars so why not a caddy?
Tazz
Rat Rods Rule!
Old 02-12-2005, 09:26 AM
1300
Well, and how then can increase its off-road capability?
Actually, project is on “research & development” stage, so I accept any suggestions that will help to make dream more really
Old 02-12-2005, 10:42 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The most recent issue of the Summit Racing catalog has the QuadraDeuce. And it don't sit much (if any) higher than most other Ford Deuce Coupes.
It gives a basic description of what parts went into it. Just look for an all wheel drive S-series Chevy and part it out.
Old 02-12-2005, 10:54 PM
lluciano77's Avatar
The Cadillac cylinder heads flow well, so you may be able to stay with them. Add a cam intake and headers.
Old 02-13-2005, 02:02 AM
1300
Maybe, somebody have suggestion, what engine can bring to its real high performance?
Old 02-15-2005, 12:23 AM
Caddy 500. I once saw a 4 wheel drive rolls royce with a caddy 500 cubic inch motor(8.2 liter). It ran in the alcan rally.
There are quite a few guys who have built 500 caddy powered four wheel drive vehicles. Takes a th400 transmission to survive behind those engines.
Old 02-15-2005, 08:22 AM
1300
Yes. Most likely it will be he. Only I do not know about a transmission... What can give substantially high speed?
