Somebody is doing things wrong with lead, how do I get through to him? - Page 8 - Hot Rod Forum : Hotrodders Bulletin Board
  #106 (permalink)
Old 04-26-2013, 08:33 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by 69 widetrack View Post
Do you guys wanna hear a story that's funny and sad at the same time?
I know this guy that, well he's a do it your selfer...and that's cool...He knows that I've done a few early Fords in the last few years and he belongs to the same club that I did 2 of these old cars for. I went to a meeting for the club about 2 years ago and explained how some metal working equipment worked and how to use it...(I only had about an hour and a half so I condensed everything down and tried to hit on the basics). The Q & A got into using lead versus body filler and I thought the whole evening went quite well.
I've kept in touch with quite a few members and about 2 months ago, one of the members called me asked if I'd come and look at a project he was working on, so I did. When I got there I was amazed at all the equipment he'd run out and purchased, English wheel, shrinker stretcher, numerous body hammers, dolly's and everything imaginable for using lead, you name it, he had the makings of a well outfitted shop. He showed me what he had done to this vehicle and so far much of what he had done looked good but he had several questions about the back panel that had been hit quite hard and aftermarket parts for some reason weren't available and wanted to know how to fix it. I explained to him that he had an English Wheel and he could virtually cut out the damaged area and build a patch panel. Gave him a tutorial on how to use it and even took a piece of metal and showed him hoe it works, all seemed good.
Today I got another call from this fellow to come over and take a look at what he had done. I was shocked to say the least. Instead of using his equipment he welded in a piece of straight sheet metal and told me that he would get the curve of the panel by molding it out of lead. We are talking a panel about 36 inches by 36 inches with radius curves that should be all around the flat piece of sheet metal he had just welded in. This didn't seem to concern him, what his concern was, how well body filler stuck to lead. Some areas will have over 1/2 inch of lead work to get the shape of what the panel should look like.
I told him he would be better off to cut out the metal he had just welded in and make a proper repair panel, he got just a little less than furious with the suggestion and told me that he wasn't about to throw 4 hours of cutting metal and welding it into place when he could get what he wanted by using lead. I tried to explain that in the long run, getting the proper repair panel made and then welding it in would be faster, cheaper and the repair would last longer. Tomorrow he's going out, scouring the city for lead...I was speechless and all I could say was well if it doesn't seem to work out the way you planned, give me a call and we'll see what we can do about fixing it.
I don't know if I should send him a sympathy card or a get well card. I'd call it butcher work if the guy was lazy and just filled it with plastic, but I think he knows better and I just don't understand why he would buy all of the equipment and not use it...Hell, even if he didn't have a wheel, a hammer and eyeball would have saved him many hours of work a hundreds in material.
It's times like this that it feels as though trying to pass on knowledge seems futile. I am now asking you guys how to get through to this person, he's a good guy and I even volunteered to do it for him on a weekend...any suggestions?
Ray
If you have told him your opinion ,Once, and he has not changed any thing he probably wont,Sad to say,
  #107 (permalink)
Old 04-26-2013, 08:36 PM
Faith - Respect - Trust
Even the gas tank and the engine where painted body color.
Name:	engine compartment.jpg
ID:	73581   Click image for larger version
  #108 (permalink)
Old 04-26-2013, 08:41 PM
[QUOTE=496CHEVY3100;1670518]If you have told him your opinion ,Once, and he has not changed any thing he probably wont,Sad to say,[/QUOT
Your right, telling him wouldn't have done a thing...put we did put on a seminar using his vehicle as an example, got his vehicle repaired properly, showed him how much better it worked seeing he had all the equipment he needed and he is now a believer...a strong believer. Probably this is the longest time I've spent to show the right way but it worked out very well.
Ray
  #109 (permalink)
Old 04-26-2013, 08:49 PM
Originally Posted by tech69 View Post
beautiful color...the work's not bad either. Nah, great work, man. You definitely know how to paint.
Thank you so much Henry, you acknowledging the paint work means a lot to me. I do appreciate it. Thank you. Finally being able to post pictures makes me feel better about the whole thing as well and thank you for your help. The photobucket thing is going to take me a little more time but I think I might use it for logging my photo's for each build as a back up.
Ray
  #110 (permalink)
Old 04-26-2013, 09:34 PM
Originally Posted by NEW INTERIORS View Post
I was pulling your leg Mr.Ray about the metal work,, I know you know what your doing and talking about,,,I can tell and see it..
And I also know all about fixing others messed up work... I'm not sure how someone can do custom work for someone and NOT give 100% to them...
As long as you do the work as if it's your car,, They will be very happy in the end with your work... I wouldn't want to give someone something I wouldn't want..
Always remember this... It's your name on that build...
It's either going to speak GOOD about you , Or BAD about you..
Well randy, I must say...I did not know you where pulling my leg...LOL...I see what other people can do and do in a lot less time than it takes me...I am my own wort critic and I know I still have a great amount I would love to learn. When I do work on a vehicle, you know, those big jobs that you pour your heart and soul into and work on it as though it is your own for six months to a year, sometimes, the hardest thing for me to do when it's done...is give the customer the keys...(That Chevy Short box was damn difficult...so he let me drive it for a bit...un bloody real...not a typical street ride, the truck is nuts)...then I felt somewhat better giving the keys back...LOL.
I feel the same way...it's my name, it's my rep...I always tell people, nobody ever says anything about an average car at a show, they only talk about the really good ones or the really bad ones. The cool thing is we get to decide how they react to what we build. I like what you said about them being happy in the end...I always tell customers that building a car and painting it is like Christmas dinner...All the work, all the preparation for Christmas Dinner is like getting the all the necessary work done on a vehicle. People will spend days preparing that meal...and it takes 20 minutes to eat it...just like the actual painting takes no time at all in comparison the work leading up to it. And just like Christmas Dinner, people may moan and complain about this and that about the meal...but in the end, they're all talking about how great it was.
Thanks Randy...I'm not to sharp this Friday...it's been a long and draining week. I'm behind on the build I'm working on now and my customer flying in on Monday or Tuesday from out West and I have a number of hours that I'm going to have to put in to get back on schedule before...then so Saturday and Sunday are full as well...
Thank You Randy for the kind words, coming from you...it only encourages be to get better.
Best to you my friend
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
NEW INTERIORS (04-26-2013)
  #111 (permalink)
Old 04-26-2013, 10:09 PM
life is a temporary assignment
Thanks for the kind words,,But !!
Remember Mr.Ray I'm just another car guy that set's no limit's on myself,, And push to out do myself everytime I do something.. I'm just a hotrodder at heart.. Born at the wrong time...
When I pro streeted this ford and a few other things to it,,, I sat with my friend for about 15Mins and he told me what he dreamed this truck would look like... And 5 weeks later, He came to get it and this is how it was sitting when he came over,, Him and his wife,,, He got out and walked around it and said..
Randy I couldn't have drawn a picture for you to come any closer to what I wanted,,, While he was checking everything out,, Me and his wife was talking and she say,, I can see in his eyes you gave him what he wanted after all these years,,,That really hit's home for me..
I went to his cruise night one night and he let me meet a friend of his,,, He asked me.. do you print out on a computer what you will be giving someone,,, My friend looked at him and said.. Nope !!!! He said well how do you do it ??? I said I spend 15mins talking to you and then I know what you want..
My friend said that's how he did it for me.... And gave me just what I dreamed of for years...
The things I do on these forums is try to give back what God gave me.. Don't always think what's in it for me ??? Give a little extra and you WILL be blessed in the long run for it...
Now.. Thanks you my friend... Here's a shot of my friends dream..
One of the worst things about these forums is,, You meet people from all over the world on here that becomes your friends,, So far a way that you most likey will never have the chance to meet them,, and you wish you could have that chance to do so,, I have a list of great guy's I would love to meet one day,, And you my friend are on that list,,
Now there's always the other list that it's best you don't meet,, LOL
  #112 (permalink)
Old 04-26-2013, 10:49 PM
That is gorgeous Randy, 5 weeks, pretty impressive. You mentioned in a previous post that you can see a project done before you start...I'm the same way...it doesn't matter if it's remodeling a kitchen or building a car and I can only speak for me but, I think that's key.
I always sit down with a customer and talk, not only about the vehicle, but, to get to know him, likes and dislikes and after a while you can often make suggestions and hit that nail right on the head. I'm on a build now for a customer that I've done work for in the past so I pretty much know what he likes. Last Summer, we talked on the phone for a few hours one night and discussed the possibility of building a car that he had been thinking about and he told me that he would be coming into my neck of the woods in a short time and we should talk more. When he arrived, we went out for several pops and I was carrying a round tube with me, I opened the tube up and showed him a rendering of what we had talked about...he said build it. It took longer to figure out the budget than it did to decide that he wanted it done...LOL.
There are a list of things that I needed more information on and that's how I ended up here...I found that many members had the information I needed when it came to suspension and drive train and it's been a great resource. Being on my own is great...I work on what I always wanted to work on and can take real pride in what I do...but I still often missed that problem solving for shops when I was a rep...this forum has help fill part of that void and I hope I've been able to give back for all the knowledge I've received.
You never know Randy...We both have very much the same interests...and when that happens, paths cross more often than we think possible...If it's OK..I'd like to send you a PM tomorrow, I'd do it today but it's about 1 AM out here and I have another early morning planned for Saturday.
Ray
  #113 (permalink)
Old 04-27-2013, 12:13 AM
Ray
Send me one anytime..1:09 AM here right now... I have something at church at 10:00am today with my Godchild,, But I should be home anytime after that.. Have a good night.. Randy
  #114 (permalink)
Old 04-28-2013, 07:36 AM
deadbodyman's Avatar
Wiki Edits: 11
[quote=69 widetrack;1670522]
Ray
It could be he's from missouri (the "show me" state) and not a canadian at all..
  #115 (permalink)
Old 04-28-2013, 07:40 AM
Wiki Edits: 11
Ray
What I do is down load my camera into a USB (vids too) for safe keeping..Well ,I have my wife do it......Then all I do is plug it in my lap top and pull them up and post them from that.....
  #116 (permalink)
Old 04-28-2013, 08:36 AM
sedanbob's Avatar
[quote=deadbodyman;1670784]
Us folks from Missouri aren't all that stubborn... some of us are much worse!
  #117 (permalink)
Old 04-28-2013, 08:44 AM
sedanbob's Avatar
... When I do work on a vehicle, you know, those big jobs that you pour your heart and soul into and work on it as though it is your own for six months to a year, sometimes, the hardest thing for me to do when it's done...is give the customer the keys...(That Chevy Short box was damn difficult...so he let me drive it for a bit...un bloody real...not a typical street ride, the truck is nuts)...then I felt somewhat better giving the keys back...LOL.
Ray, I think I told you about my friend painting a '33 Cabriolet for another friend. Mark, the painter is totally busting his butt and making this car beautiful, not just a great paint job, but all sorts of refinements and nice touches. I have teased Brian, the owner, that this car is coming out so nice that Mark might not give it back! Mark has been pouring heart and soul into this car.
Bob
  #118 (permalink)
Old 04-28-2013, 10:21 AM
Well Mike...I'm just happy I figured out how to post pictures...it was getting embarrassing...one step at a time...LOL...Now...just like yourself...I gotta figure out how to get more pictures from camera onto my computer...the ones I have on my computer where put on there my my neighbors kid.
You know Bob, not all people would understand the fact that it is difficult to give a car back to a customer after you've poured your heart and soul into it...it's like it becomes a part of you..almost like your own kid and I've never seriously considered putting up one of my kids for adoption...for any long periods of time...LOL
Ray
  #119 (permalink)
Old 04-28-2013, 11:28 AM
sedanbob's Avatar
Yeah Ray, adoption leaves too much of a paper trail -- better to just leave them by the side of the road!
I painted a Cutlass for a friend. Took it from oxidized gray to beautiful black. I was quite proud of it. He got a lot of compliments on the car after that. Kept it 3 weeks then sold it! If I had known that I would have turned down the job. I spent longer than that getting it prepped.
  #120 (permalink)
Old 04-28-2013, 11:39 AM
I hate that more than you know. I had a friend of a friend come to me years ago with a 70 Firebird (You know how much I love I love my Pontiacs). It was a decent car, a bit of rust but very respectable. He went on and on about how much he loved the car, always wanted one finally found one for a reasonable price ($750) and how little money he had. I listened as he told me that if I could just patch it up and paint it he would be forever grateful but he only had limited funds.
I cut out the rust, repaired the quarters, blocked the car until it was as straight as an arrow. When he picked up the car he was overjoyed and again told me how he had always wanted one and just loved the car. He paid me the agreed upon amount (which basically covered materials), drove off into the sunset.
Two weeks later, he auctioned the car off for almost 10 times what I charged him. Did he have a change of heart, no, this was his plan the whole time...was I pissed, still am.
Ray
To lead or not to lead?????? gearhead13 Engine 1 04-29-2010 12:52 PM
Get the lead ...in? Slomotion34 General Rodding Tech 4 04-30-2008 09:23 PM
use of lead Rag top bird Body - Exterior 1 11-27-2007 08:11 PM
Why Lead? DesertrusT Engine 16 04-03-2007 07:57 PM
Lead jrm123180 Body - Exterior 3 12-03-2004 01:53 PM
