"SOMEDAY" has finally come! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-24-2012, 07:36 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Thanks ssmonty, good info on the header gaskets. I have the ceramic coated Tri-Y's and they are the heaviest headers I've ever had my hands on. Personally I like that "tinny" sound you get with headers and a healthy cam, couple that with a set of properly adjusted solids and it makes sweet, sweet music. Haven't decided on exhaust yet but I've heard a couple cars locally with Hooker Aero Chamber mufflers and I really liked the sound. Cam came today, other than a few odds and ends I have everything else. Itchin' to start assembling!!!
  #17 (permalink)
Old 10-24-2012, 08:11 PM
I miss spoke about the "tinny" sound as I like it too, just not on a "sleeper".
Caught more than a few guys off guard in the 1980s with an 86 SS Monte with a warmed up 350.
ssmonty
  #18 (permalink)
Old 10-26-2012, 03:19 PM
Hippie's Avatar
Change of plan.......
Well, it appears my 305 build isn't going to happen. I didn't change my mind, the machine shop called a little bit ago and my block is cracked through the lifter valley. I'm still going ahead with the build but it will now be a 355 instead since I'm fresh out of 305 roller cam blocks and have a "hopefully" good 350 roller block. I'm kind of disappointed because I really wanted to see what I could get out of it, I guess I'll just have to suck it up and "make do" with what I have.
  #19 (permalink)
Old 10-27-2012, 07:49 AM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
sorry to hear that hippie, had a Tbi roller 305 in my 3rd gen camaro with a 700r4, i could sit and roast my truck wheels on the back sittin and spinning that thing up to 4500 rpms, swirl ports but that engine could just eat pavement. best vacuum you could get to, because come to think of it, i never had brake fluid, because the rear drum brakes. Itd catch a blazer doing 85 over 100 yards in 10 seconds from 45 to WOT. eventually head gasket blew while some family members were driving it (with new brakes of coarse) we disasemble it And get this. the block had a mechanical fuel pump boss. never seen such a thing on newer blocks. Especially roller blocks. then they have the head gaskets about the size of a 400s bore. can someone tell me why they put these big round head gaskets on the Tbi engines?
  #20 (permalink)
Old 10-27-2012, 02:37 PM
Hippie's Avatar
Well this just keeps getting better and better...... The thrust flange on the 350 crank is wasted. Not sure what direction to take now. I have to do something though, I'll drop the block off Monday and make sure it's usable then take it from there. I do have a new Scat 383 1 Pc. RMS crank and KB-135 18 cc D-cup pistons but my DCR would be in the 8.1 range with the XR264 cam and L-31 Vortec heads. It makes some impressive numbers on DD2000 though, it might just be worth having to run Premium. Stay tuned......
  #21 (permalink)
Old 10-27-2012, 02:40 PM
Banned
unless you're supercharging it there's no reason that engine couldn't run on 87 octane. 87 is your regular right?
  #22 (permalink)
Old 10-29-2012, 11:40 AM
If I was you I'd go with the 383. More power, for not that much more in gas money It'll be worth it
  #23 (permalink)
Old 10-29-2012, 11:51 AM
vinniekq2's Avatar
decide on the purpose of the engine,decide how to get there, search for parts that fit your need,,,
  #24 (permalink)
Old 10-29-2012, 02:16 PM
Hippie's Avatar
Ran into a friend of mine a couple hours ago and mentioned my dilemna. He told me he had a roller cam 350 that had been already hot tanked with new cam bearings and core plugs and the crank polished about 7 years ago that he wrapped in plastic and then buried in the back corner of his shop when he decided to go with a 454 instead. Block and crank are both still standard too. I say "had" because it is now mine. Price was cheap and I get all the peripherals including windage tray and a set of '882 heads. Not sure what I'll do with the heads but they go with the deal. Still getting the other block tanked and checked though. I'll bag it and set it on the shelf for next time.
I quickly talked myself out of the 383, it's serious overkill for what I'm doing. This is a 1/2 ton truck with an 8 Ft. bed not a drag car, anyway the 383 would just over power the rear tires and get me in trouble and I don't need any help doing that. I've managed to do that all on my own for 57 years. A good friend wants all my 383 stuff and has something I need a lot worse than a 383, that made the decision even easier.
The 355 with the XR264HR-10 cam, Vortec heads and Tri-Y headers will work just fine. I had thought about getting different pistons to bump up compression just a hair but the friend with the 350 works for a large local fuel distributor and he told me that any future builds he does will be based on 87 being the "good" stuff. He told me to expect to see 85 Octane showing up in our area in the not too distant future followed by 89 and up getting harder to find in less populated areas. He is not the first person I've heard this from either. I'm smack dab in the middle of "less populated", what I'm putting together now should still run fine on 85.
As soon as I can get everything through the machine shop I'm ready to start spinning wrenches!!!
  #25 (permalink)
Old 11-10-2012, 06:32 PM
Hippie's Avatar
Still waiting on the machine shop......... I'm starting to get a little antsy. I was really hoping to be assembling by now. I guess I've waited this long a few more days won't matter.
  #26 (permalink)
Old 11-10-2012, 09:19 PM
vinniekq2's Avatar
It takes a week or more to assemble in your spare time so an extra day at the shop is no big deal
I finally found a "Time out kid" that I don't feel like kicking! MARTINSR Off-Topic 4 02-29-2012 05:18 PM
NOS Rambler Key I "cut" today (finally). MARTINSR Off-Topic 3 09-03-2011 10:48 PM
Finally looked at "private messages" trblmker Introduce Yourself 1 11-10-2009 07:36 PM
"I'm gonna fix it up someday"....yeah right! Nightfire Hotrodders' Lounge 24 03-27-2005 01:05 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
