"SOMEDAY" has finally come!
I'm FINALLY going to get an engine built for the truck after too many years of "analysis paralysis", false starts and 100 other excuses.
It's off to the machine shop in the AM! The end product will be a 9.17 to 1 310 CID SBC using an '87 roller cam block with Speed Pro flat tops; Comp Cams XR264HR-10 roller cam, '062 L31 Vortec heads, Performer intake w/Q-jet and Doug Thorley Tri-Y headers. I could have done a 350 too but I wanted to see what I could squeeze out of a streetable 305. The cam and heads were literally a last second change. I was originally going with a ZZ4 cam and L30 heads but my SCR was going to be pushing 9.9 to 1. The ZZ4 cam gave up too much low end to a Ramjet or Vortec cam acording to DD2000 and I don't really want to have to buy premium, especially with a 34 gal. tank! FWIW DD2000 shows the XR264HR making nearly identical low end TQ to the Ramjet and Vortec cams, actually just a hair more but not enough to talk about.
Sounds like a good streetable combination.
Will the heads support the lift of that cam?
Fact is stranger than Fiction |
I really don't like to quote DD2000 numbers, they don't mean much but I use it to compare potential combinations to actual builds I have done (years ago) or other real world builds. I have been able to duplicate real world results pretty closely but DD is always a bit higher. If this turns out and runs decent I may pony up for some chassis dyno time after break in. It looks that good.
Definitely. Wouldn't want much more though. |
Awesome
Best of luck. Looking forward to seeing your smokin tyres.
My c10 has a 305 performer cam w/ milled vortec 906 heads. A 305 for a daily powerplant is fine. Do not over cam a 305. Take advantage of its good points, the stroke and rod ratio. A big cam is going to place the band to high in the rpm range. Build the whole package to compliment. It will work well and perform.
Im set with a 3.73 gear and converter built by dynamic like the GNX style 3000stall. Very street friendly, and drives nice. Not slush box lose. A 2400-3000converter makes it fun. 260 hp is fun to cruise around and brake torque, nothing wrong with that. Plenty of good times with that. In the recent years my 305 proved itself to last. So I supercharged it. Yowee, it has some power now at 10 psi. Are you gonna find you an anlog girl? Did you listen to JLynne's album long wave? |
Good for a smooth daily drivin vehicle trying to pull with torque. Not saying it is good for a high winding drag set up.
I'd just find a good cheap 305, do a "in the garage clean, hone, and rering" job on it and run it. |
[QUOTE
I'd just find a good cheap 305, do a "in the garage clean, hone, and rering" job on it and run it.[/QUOTE] With a bolt on supercharger..... 7.4:1 cr 230+cfm ports 1.94x 1.50 |
I'm building a 305 because I want to build a 305 and since I'm the guy paying the bills that's all the reason I need. |
| I finally found a "Time out kid" that I don't feel like kicking! | MARTINSR | Off-Topic | 4 | 02-29-2012 05:18 PM |
| NOS Rambler Key I "cut" today (finally). | MARTINSR | Off-Topic | 3 | 09-03-2011 10:48 PM |
| Finally looked at "private messages" | trblmker | Introduce Yourself | 1 | 11-10-2009 07:36 PM |
| "I'm gonna fix it up someday"....yeah right! | Nightfire | Hotrodders' Lounge | 24 | 03-27-2005 01:05 PM |
| Hey croz look """"IMPORTS SUCK""" | 78 monte | Hotrodders' Lounge | 14 | 08-30-2002 01:13 PM |
