We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 06-13-2007, 04:02 AM
Red Grant Red Grant is offline
Somendar Singh's groove and LS7 engine...
Does his groove improve LS7 engine as well?
or does it only apply to older engines?
Old 06-13-2007, 06:16 AM
RippinRon's Avatar
RippinRon RippinRon is offline
The LS series heads combustion chambers are far more efficient than the older designs. Hacking up a new set of heads from a $14000 engine seems idiotic to me.
Old 06-13-2007, 09:44 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
I could not have put it any better, RippinRon
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Old 06-13-2007, 10:17 AM
Jmark's Avatar
Jmark Jmark is offline
Hmm, sitting here with my mouth zipped shut!!!! LOL
Old 06-13-2007, 11:15 AM
automotive breath's Avatar
automotive breath automotive breath is offline
If I weren’t so foolish, I would do the same!
I haven’t had an opportunity to do any work on the LS7 engines; I personally
don't know anyone that has one. It’s an excellent high performance engine
that responds well to modifications so I’m told.
I do plenty of work on the LS1, both production and aftermarket heads. They
respond to porting and the grooves very well.
Old 06-13-2007, 04:54 PM
steveyb4342 steveyb4342 is offline
On the learning curve.
Can I be dumb and ask what this groove is?
Steve
Old 06-13-2007, 04:59 PM
Jmark's Avatar
Hi Steve. It's new to lots of people. Very interesting concept.
Here is one link from a while back.
and another one.
Mark
Old 06-13-2007, 05:08 PM
Thanks Jmark, let the reading begin!
Steve
Old 06-13-2007, 09:01 PM
machine shop tom machine shop tom is offline
Bumping this post over the deleted double of it.
tom
Old 06-13-2007, 09:05 PM
To automotive breath:
So do you think it's possible to improve upon stock LS7 engine using the grooves?
Old 06-13-2007, 09:58 PM
Rick WI Rick WI is offline
Red, what in gods green earth is the current issue you have with the stock LS7 head that I know for a fact will run 12:1 on pump gas from Cleveland to Little Rock Arkensas in 95 degree heat and stop and go traffic AND makes well over 500 SAE corrected flywheel horsepower with about 27 degrees of total timing, with the AC running.
Grooves in this type of cylinder head will do no good. It is a superb head as is. Not a cylinder head you'd want to hack up.
Do yourself a HUGE favor one day and go to a car show and spend some time at the GM Performance Parts trailer and exhubit area. Many times they have their LS cylinder head engineers there. They are a wealth of knowledge and have always been willing to share information.
Old 06-13-2007, 11:53 PM
Red, I'm fairly certain the LS7 engine can be improved with the grooves.
Do you have a LS7? If so what are your plans for it?
Old 06-14-2007, 04:47 AM
RippinRon's Avatar
Not to mention 28mpg to boot.
Old 06-14-2007, 11:40 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
I was under the impression the LS7 has a 11:1 compression ratio, not 12:1.
Old 06-14-2007, 11:49 AM
Bob C Bob C is offline
Auto Concepts
What's wrong with taking a good head and making it better? I don't know of any head that can't be improved. Cut the thing up and see what you can do.
Bob
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
