Someone ejumikate me - early Ford front hubs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2008, 02:58 PM
Wiki Edits: 49
I know 40-48 Fords used two different brake drums. One fits over the hub and the other fits inside the hub. Question.... is there a difference in the hubs or are the drums just different????
Old 02-17-2008, 04:04 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
From what I've read on Hamb, they are different. They say to use the later ones on brake upgrades. I have 40 hubs & drums (off) if you need some pics.
Old 02-18-2008, 06:24 PM
Centerline, I am shooting from the hip because I CRS. But there is a slight difference in the front spindles on the 40 and the 41-48. I am not sure they will interchange out right. I have seen a mix and match of the two different designs on the 41-48 so I think it is a different supplier issue instead of the not fitting/interchanging issue. If I can remember to do it, I will check some of my references when I go to the shop tomorrow.
Trees
Old 02-18-2008, 06:48 PM
CL, I read your other thread and have a better ideal as to what you are trying to do. First of all, I would not be very concerned about the stopping power of the 41-48 brakes on the light ride you are planning. I drove my 36 PU for 115,000 miles all over the country with a 39 Ford front axle and brakes. Granted, I had 57 Chevy rear brakes, but they were no big improvement over the 41-48 rears and I had an adjustable proportional valve so I could easily lock up all four if necessary. I never felt there was a braking problem at any time and I had my fair share of "panic" stops.
Regardless, I like the F100 ideal over trying for Lincoln parts. I can assure you they will be much more heavy duty than the Ford parts and will not be a simple bolt on. And talk about being hard to find!!
Trees
PS I just passed on the last full set of 41 spindles, backing plates (front and rear) and drums (front and rear) we had left over from the business coupe. Sorry, did not know.
Old 02-18-2008, 09:54 PM
Wiki Edits: 49
Thanks for the info, Trees.
Here's my current plan. I already bought a set of 39-48 backing plates (got them on E-bay yesterday). I'm going to adapt a set of mid 70's GM big station wagon 12"x2" self energizing brakes to those backing plates. This shouldn't be too big of a task and I'll use early (39-40) style front hubs (where the drums fit OVER the hubs) which will make things easier when it comes to servicing and replacing parts. All the GM brake stuff is available at Auto Zone or Napa so parts shouldn't be a problem.
Not that I'm a big fan of the Hamb but there is some pretty good talent over there and a couple guys have done this and claim it works very well. Kind of like the Buick drum mod but using stock drums. I'll do a "how I did it" article when I'm done and we'll see how it comes out. If it doesn't work there are always the F100 or stock juice brake options.
Old 02-19-2008, 05:31 AM
F&J F&J is offline
There is supposed to be a difference in the 40 plates compared to late 40s??? Seems like I read that on a Hamb thread about the Chevy brakes. Someting about "voids" and "valleys" in the plates where either the shoe touches or hardware is mounted?
Put up some pics when you start getting the stuff delivered, I am scrounging too. I think I can get some 45 fins from a yard near here...as well as the chevy stuff too.
Old 02-19-2008, 10:03 AM
Wiki Edits: 49
From what I can tell the ones you want for this swap have the little clamp piece that holds the shoe against the backing plate. That piece has to be removed and a hole drilled in the appropriate place for the "nail" and cup washer which essentially do the same thing.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
New front clip in a 46 Ford... 46FordSuperDeluxe Engine 0 04-25-2007 12:54 AM
problem installing front sway bar 40 ford. EGOP8 Introduce Yourself 3 03-25-2007 08:05 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Selling a mid 60s, early 70s Ford 8" bildo95 Transmission - Rearend 2 08-19-2002 12:12 PM
